Hi,
I have just installed some US through the grill fogs temporarily on my car, just to try out the look. I have read that the wiring is already in the harness that goes to the headlights, and is curled up if not in use? Is this the same for a rear fog light?(I have a rear fog light I want to install) I guess I will need the two stage dash switch to install both front and rear fogs, but are the wiring to be found behind the dash as well? I also understand the US fogs did not go through a relay, if so I guess the wiring goes through the fuse box?
I am no good at electrics
