I have four spring plate bushings ready to replace the ones I removed last weekend. The four bushing have the same part number. Are replacement bushing supposed to be the same inside and outside? I'm confused?
[SIGPIC][/SIGPIC]
1967 911S Coupe
1991 944S2 Coupe
Past projects:
1967 912 Coupe
1969 911T Coupe
1985.5 944 SR Coupe
Joe-
Are these for the '67S or the 912? All the '67S cars had the updated springplates with the vulcanized bushings, AFAIK, but the '67 912 cars had the early style ('65-66) removeable bushings until chassis #354938, and the ''67 911 Normal until chassis #307325. The early style removeable bushings are very different sizes on the inside pivot arm compared to the outside. The later style (vulcanized) are the same.
Check this thread on PP for more info and pics.
What replacement bushings are you using? Neatrix? Polyurethane?
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
PCA National DE Instructor
Read my surf novel!
My '67 Karmann has the later, same size bushes. Any Idea when they (Karmann) Changed over? I'm Vin 461786.
Dave
911S registry #1103
R-Gruppe #513
1967 912 converted to 2.2
Period Dune Buggy
Some drive Porsches' to be seen.....
I prefer it when nobodys looking.
Thanks for the info Ttweed. The bushings I removed were the type that were vulcanized to the spring plate. I have three OEM Porsche bushings and one Neatrix bushing. I am trying to locate a fourth OEM bushing.
The Stoddard catalog shows a cut-off two different bushing at "Up to #307325."
[SIGPIC][/SIGPIC]
1967 911S Coupe
1991 944S2 Coupe
Past projects:
1967 912 Coupe
1969 911T Coupe
1985.5 944 SR Coupe
I was not aware that Porsche ever sold the bushings for the updated springplate separately, as they were vulcanized to the springplate pivots. I thought you had to buy the whole springplate assembly to get new bushings, and that was the reason for the aftermarket replacements being made.Originally Posted by Sacto S
I have a set of all 4 Neatrix bushings I would sell you for $40 if that would help.
TT
Tom Tweed
R Gruppe #232
Read my surf novel!
