Thread: Small metal pieces in fuelpump?
    A friend has a 73E. His car stopped running, he managed to restart, but it died again with some popping noises. He noticed the electric fuel pump was silent, so he removed it. After dismanteling the end of the pump he found some small metal shavings(shiny metal, not corroded). The pieces was under 1mm, but they managed to stop the pump at the roller bearing. After cleaning and reinstalling the car runs fine.
    But where does the metal pieces come from, are they from the MFI, and if so could this be a sign of something serious? As I understand the pump was quite resonatly rebuilt/overhauled in the US.
    I see from the manual that there is a fuel return from the MFI to the filter, is it possible to dismantle the fuelfilter and check for more metal shavings? Does the fuel, when passing the filter from the MFI back to the tank actually get filtered or just passes by unfiltered at the top?
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Anyone have a clue about where the metal shaving/piece might come from.
    I can't say where the metal is from, it could be from the electric fuel pump itself, I think I would pump the fuel out of the gas tank and pull the filter sock from the feed line. If there is no metal there my guess would be that the metal came from the fuel pump itself. Even if there is metal I don't know how it could be from the injection pump, since I don't see how the mechanical part of the pump could get into the fuel supply, I think they are pretty much separated. If it never occurs again, just put it down to cleaning out machining remnants, if it keeps reoccurring, well then you know what you have to do !
  1. Take two, they're small.
    By LiveFromNY in forum General Info
    Last Post: 03-06-2019, 04:08 PM
  2. WTB: Small pieces and parts for '65 restoration completion
    By 19-911-65 in forum For Sale: 911 Parts
    Last Post: 11-15-2013, 08:12 AM
  3. NOS Bendix Fuelpump for sale
    By 67Porsche911S in forum For Sale: 911 Parts
    Last Post: 03-24-2012, 09:25 AM
  4. 912 NOS Engine Sheet Metal Pieces
    By BBausser in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 09-26-2010, 12:39 PM
  5. Metal on metal 'bang' on bumps as speed.
    Last Post: 09-24-2005, 10:03 PM
