When did the 73S get 7R cases instead of 4R/5R cases? I have engine number6330398 in my 73S and the case is a 4R/5R.
Any other info from members with builddate and enginenumbers would be apreciated.
Early 911S Registry #931
1971 911 2.2T Coupe Tangerine
The original case on my 12/72 build date 1973E is a 7R/7R, and it has not been apart. I have not been able to confirm definitively when Porsche stopped using the 5R cases - most people think it was in the early spring of '73, but there seem to be several cars with 7R cases from December '72 or January '73.
See this thread for more discussion.
http://www.early911sregistry.org/for...ad.php?t=12656
Bob
1973 911E - Viper Green
1973 911T - Light Ivory, becoming Glacier Blue RS
My car has chassis number 9113300437, and the invoice says 721001. Its a 1973 model. A total of 1430 cars where built for model year 73. Probably built in ?
Another strange thing from the original dealer invoice: Typ 911534 911S Coupe. What is the "typ" number?
The reason I ask is that I am considering buing a unstamped 7R case for the car. Would stamping it with the original engine number be considered correct? And if so who could stamp it with the correct numbers?
My 73 E built in Aug? (I'll confirm) of 1972 has a 4R/5R case. Chassis number 0069.
2004 GT3 Carrara White with a few mods...
2011 987.2 Spyder White, LWB's, 6 speed... Crazy Fun!!!
R #208
S #607
A #76
I have a 2.4T engine witha 5r-7r thats prob. as close as youll get,
Jeff H.
72 911
914-6 GT
My '73 Carrera was completed 1/16/73 and has a 7R/7R case.Originally Posted by Zithlord
I would just keep the non-matching but correct '73S motor in your car. What is to be gained by stamping a blank case with the correct serial #? In addition you will likely never find the correct dyes to stamp it correctly. These #s are very unique and I know of only one source for the correct stamping.The reason I ask is that I am considering buing a unstamped 7R case for the car. Would stamping it with the original engine number be considered correct? And if so who could stamp it with the correct numbers?
OTOH it does make sense to buy the blank case in the event you break your current motor or you want to build a wicked hotrod motor on a stronger 7R case.
Brian
'71T
R Gruppe #299
