Thread: Gas tank lateral support
    I need to get the part in the picture. I am preparing, an collecting parts for doing the tank support/front pan job on this car after I return from summer holidays. There is a hole in this part right below the battery box. The hole dos not show in the picture. I found at Resto design the part number 4 under chassis section. Is this the correct part? I have allready bought pan and support from Rennspeed in the US.
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Dec 2004
    SE Michigan
    No, #4 is the piece that is *inside* the trunk area next to the gas tank. You are going to need to 1) fabricate that piece, 2) find a donor for that piece or 3) find an NOS replacement, which I believe includes the entire sidewall and maybe part of the shock tower.
    I would chose option 1, but you've circled a pretty big area. However, that is a fairly flat piece. A donor is likely rusty...maybe the very bottom portion from a later vehicle is the same though?
    Bill G.
    EarlyS #718 | RGruppe #437
    Aug 2003
    Van Nuys, Ca
    actully bill is correct with his assumption about later model chassis sections being adaptable to your car. We just did this using a 82 section on a 70 model. it takes a some detail work, but in the end it is indistinguishable
    Member #755
    Conda Green 70 911S
    70 black 914-6 3.2
    70 911 "Speedster" project
    "74 IROC" tribute Jade Green RSR
    Thanks a lot guys!
  1. '73 RS front tank support.
    By Flat Six, inc. in forum General Info
    Last Post: 04-16-2014, 01:12 PM
  2. WTB SWB left and right side lateral gas tank supports
    By 911scfanatic in forum For Sale: 911 Parts
    Last Post: 12-09-2012, 05:08 PM
  3. SWB fuel tank support
    By Neil '67 911S in forum Technical Info
    Last Post: 12-05-2012, 11:29 AM
  4. FS: Fuel Tank Support
    By WCB4 in forum For Sale: 911 Parts
    Last Post: 05-05-2008, 11:47 AM
  5. WTB NEEDED rhs lateral fuel tank support!!!
    By mjmoran in forum For Sale: 911 Parts
    Last Post: 11-12-2007, 11:04 AM
