Thread: through-rocker oil line install
    Dec 2004
    SE Michigan
    Anyone have pictures of the oil lines installed inside the rocker (ala 70S)? I'm modifying some post-74 lines for installation inside the rocker. TIA.
    Bill G.
    EarlyS #718 | RGruppe #437
    Oil Lines in Rockers
    Something like this:
    Bob
    Early S Reg #370
    Hi,
    Here are some from my 70S resto. Originally the pipes entered the sill through a modified kidney bowl. The wing closer panel is also specific to the 70-71 S but any can be modified to suit. (From 72 the wing panel closers are different).
    Hope the pics help
    Alan
    Dec 2004
    SE Michigan
    Bob and Alan,
    Very helpful pics...thank you so much.
    Bob, did you have those lines made? They look stainless.
    Bill G.
    Stainless oil Lines
    Yes Bill, I made the stainless to emulate the style of the original 1969 S brass lines and moved the thermostat to the inner fender to get the weight forward.
    The fittings and the line size are a mix of the smaller 1967, 1969 and the larger mid 1980's oil cooler metric threaded fittings.
    Bob
    Early S Reg #370
  1. Horn re-Install
    By karlusmagnus in forum Technical Info
    Last Post: 10-31-2022, 03:25 AM
  2. FS: Complete set of 12 early 911 forged rocker arms and rocker shafts.
    By Neil '67 911S in forum For Sale: 911 Parts
    Last Post: 03-04-2013, 05:25 AM
  3. 1965 911 300378 Rocker Schutz line.
    By ErichW in forum Technical Info
    Last Post: 02-11-2013, 09:43 AM
  4. WTB: main oil line junction, between case and line
    By mcaterino in forum For Sale: 911 Parts
    Last Post: 12-06-2010, 04:47 PM
  5. Help on H4 Install
    By gsjohnson in forum Technical Info
    Last Post: 10-21-2009, 06:28 AM
