Page 148 of 278 FirstFirst ... 4898138146147148149150158198248 ... LastLast
Results 1,471 to 1,480 of 2771
Thread: 911T Cars for Sale
  1. #1471
    Apr 2011
    SF Bay Area, CA
    not mine / no affiliation
    1973 911T Coupe - $52,500
    https://austin.craigslist.org/cto/5646111601.html
    Seller's ad:
    1973 1/2 Porsche 911T.
    The very best Year !
    Great Body.
    Featuring 3.0L Engine.
    New Tires
    New Batteries.
    All original glass.
    Solid Floors.
    No interior.
    Clean Title.
    Rust Free.
    Momo Steering Wheel.
    California Car.
    Starts Runs and Drives.
    Fantastic Investment Grade.
    Special order color. Originally.
    VIN: 9113102808
    Currently in between Porsches. Sold my 73.5T Targa, now suffering from serious withdrawal symptoms. Attending Rennsport Reunion VI didn't really help getting over it.
    Past: '73.5T Targa, '12 991S Cab, '07 987
  2. #1472
    FS: @BaT - 1971 2.2L 911T Coupe
    Quote Originally Posted by bodaabod View Post
    1971 Porsche 2.2L 911T Coupe
    VIN: 9111100466
    Engine: 6119546
    Trans: (915 replacement)
    Color: Silver Metallic (originally Gold Metallic-88)/Black Leatherette-11
    Mileage: 25.915 (indicated on newer replacement speedo)
    Auction Estimate: -
    Sold for: US$36,000
    BaT Description:
    This 1971 Porsche 911T is a driver that retains its original engine #6119546 backed by a later 915 transaxle. The seller purchased the car in September 2013 and believes the previous owner had it since at least 1980. He has driven it around 2500 miles in three years. Following a September, 2015 run-in with a deer, bodywork was performed at a restoration shop and included repairs to the right front fender, door, and quarter panel. Rust repair was performed forward of the fuel tank at the same time. This car features a partially modified interior using later Porsche seats and door panels. It was recently tuned up and had its Weber carburetors rebuilt last year. The car is sold with a Porsche CoA and a clean New York title.
    Originally gold, this car was painted silver before the seller’s ownership. It is believed to have been an engine and windows-out repaint as the seller cannot find evidence of the original color. At the time of the accident repair, new front turn signal assemblies and taillight lenses from Stoddard were fitted and the “sugar scoop” headlight rings were replaced. The rusted headlight buckets were replaced at the same time. The seller believes the car was hit at some point in the past, citing an ill-fitting rear decklid. The mag wheels fitted above are included with the sale. The fitted Fuchs are non original, but are correctly date-coded. The seller notes that they could stand to be refinished. Some rust bubbles are present on the bottom of the driver’s door and around the fuel filler. The passenger’s side of the car has been restored and is said to be free of rust.
    This car is fitted with A/C, which appears to be a Delanair system. Door panels and carpets are from a later 911. The seats feature cloth Porsche-script centers and appear to be from a 944, though they carry a 928 part number. Original-type seats and correct rails are included. An aftermarket radio and speakers are installed, as is a later electrically-controlled speedometer dated 8/84. 26K miles shown on the odometer are not an accurate lifetime total. The oil temperature and pressure gauges stick, though a tap on the glass is said to free them. The seller states all other instrumentation works. There are some waves in the dash, but cracks are only apparent in the speaker covers. Later 911 door panels looks to be from an SC, and the driver’s side door pocket is included but not fitted. Rear speakers are mounted above the original parcel shelf.
    The 2.2L engine is original, though the transmission is a later 915 transaxle with a provision for an electronic speed-sender. It is pictured here with the stock air cleaner removed. Third and fifth gear synchs are reported to be worn and the seller believes the oil tank to be a larger capacity item from a later 911. Weber carburetors were rebuilt in the winter of 2015. Records show that a top-end rebuild was performed in 2005, and included the addition of a late model oil pump and a new sump cover. Receipts showing the parts replaced are available.The car is fitted with Carrera tensioners. It also benefits from a recent tune-up, and SSI heat exchangers. Records show that a top-end rebuild was performed in 2005, and included the addition of a late model oil pump and a new sump cover. Receipts showing the parts replaced are available.The car is fitted with Carrera tensioners. It also benefits from a recent tune-up, and SSI heat exchangers. The rest of the pan looks dry, there is rust on various suspension and chassis parts.
    There is the COA showing the original specification. This 911T looks like an affordable longhood driver with its original engine.
    Doug Dill
    1973 911E Coupe
    PCA #1987109761
    Early 911S Registry #548
  3. #1473
    Original air cleaner moved for better view of engine compartment and Webers. PM if you have questions.
  4. #1474
    FS: @Hemmings - 1971 Porsche 2.2L 911T Sporto Targa - 26K miles
    I assume it is being sold by a flipper and it is not running.
    1971 Porsche 2.2L 911T Sporto Targa - <27K miles
    VIN: 9111112209
    Engine: -
    Trans: -
    Color: Black (originally Light Ivory)/Black
    Mileage: 26,845 (indicated)
    Price: US$55,000
    Seller's Description:
    1971 Porsche 911T Targa Sportomatic / 26k original documented miles! / Numbers Matching Super Rare Car!! Last owner bought in 1974 with 17k and RARELY drove it. It was put into dry heated storage in 1989 and hasn't started since. Properly stored with ATF in the cylinders and a clean fuel system. Completely original execpt for a color change in 1974 and a windshield replaced. Car was not wrecked, he just couldn't find a black targa. The car started as Light Ivory and was changed to Black. Absolutely rust free. Beautiful pan! This car has never been restored, modified or taken apart. Car has been inspected by a professional Porsche restoration company and they verified the miles and originality. Includes a Porsche COA. Also, a copy of the original title from 1974 when purchased. Original Fuchs Wheels and Comfort Equipment car! Sportomatics are very rare and fun to drive. Wouldn't take much to get this rare 911 back on the road. Car was pulled from 27 years in storage.
    Doug Dill
    1973 911E Coupe
    PCA #1987109761
  5. #1475
    FS: @PCA Classified - 1972 911T 2.4L Coupe
    1972 Porsche 2.4L 911T Coupe, Ad#23591
    VIN: 9112501394
    Engine: -
    Trans: -
    Color: Silver/Black
    Mileage: 105,000 (71,744km indicated)
    Price: US$45,000
    Partially restored Euro T coupe bought in Italy. VIN# 9112501394. Owned since 1985. EPA waiver, DOT approved. Unmodified solid body and chassis. ‘S’ trim package. Webers on matching 2.4L per COA. Aluminum front beam, trailing arms; new BF Torino Monte Carlo black leather sport seats. Euro gauges + VDO volt and amps. Fuchs 7 & 8 inch with new Falken 195 & 215/65 tires.
    Doug Dill
    1973 911E Coupe
    PCA #1987109761
  6. #1476
    FS: @PCA Classified - 1972 911T 2.4L Targa
    1972 Porsche 2.4L 911T Targa, Ad#24027
    VIN: -
    Engine: -
    Trans: -
    Color: Silver/Black
    Mileage: 119,318
    Price: US$39,000
    Unmolested original & nicely optioned numbers matching Targa with 5spd, factory air, & fully functioning MFI. Car is in fair condition overall with good top, body (one re-paint) and pan, but some rust & body repair, motor work and interior refurbishment is needed. A great candidate for a high quality restoration. Repair parts, manuals, more info & pictures available.
    Doug Dill
    1973 911E Coupe
    PCA #1987109761
  7. #1477
    FS: @Silverstone Auction - 1972 2.4L RHD 911T Coupe
    Actually a 1973 Model Year, the restoration firm took some liberties in the finishing of this car . . .
    Silverstone Auctions Classic Sale, July 30-31, 2016
    1972 2.4L RHD 911T Coupe, Lot 924
    VIN: 9113500394
    Engine: 6530636
    Color: Royal Purple/Black
    Mileage: 54,566 (unsubstantiated)
    Auction Estimate: £85,000 - 95,000/~US$110,075 - 123,025
    Sold for: £84,375/~US$111,250
    Auction Description:
    This original right-hand drive, UK-delivered Porsche 911 2.4 T was first registered in 1972 and was specified in the ‘groovy' colour of Royal Purple. Showing just 54,566 miles on the speedometer, it was discovered by our vendor as a sound and complete restoration project. Whilst the mileage could not be fully substantiated, the vendor believed it to be genuine and set about a ground up restoration 2 years ago.
    Almost every single component of the car was stripped to a bare shell and rebuilt over many hundreds of hours by the vendor's in-house mechanics. The engine, gearbox, and differential were then fully rebuilt and the bare shell E-coated and finished in its original colour of Royal Purple. The interior has been fully re-trimmed and the whole car has been reassembled with great attention to detail. A significant number of bills and receipts can be found in the history file for parts alone, along with a CD containing photographs of the process.
    The history file also contains a Porsche Certificate of Authenticity confirming this is a matching numbers 911 2.4 T. In addition, there are a number of older MoT certificates and service invoices supplied with the vehicle. Offered at public auction for the first time in many years, we welcome pre-sale inspections and are delighted to be offering such an interesting Porsche 911 from the pre-impact bumper heyday.
    Doug Dill
    1973 911E Coupe
    PCA #1987109761
  8. #1478
    FS: @Mecum Monterey - 1973 2.4L 911T MFI Coupe
    1973 Porsche 2.4L 911T MFI Coupe, Lot R370
    VIN: 9113100811
    Engine: -
    Trans: -
    Color: Gulf Blue/Black Houndstooth Pepita
    Mileage: -
    Auction Estimate: $175,000 - $200,000
    NO SALE - Highest bid $135,000 "The BID Goes On . . ."
    - Sold new and serviced at Vasek Polak Porsche
    - Matching numbers engine
    - Three owner Southern California car
    - Recent nut and bolt rotisserie restoration to concours specification
    - Gulf Blue exterior
    - Black/Houndstooth Pepita interior
    - Original sheet metal
    - Carello fog lamps
    - Blaupunkt Frankfurt radio
    - Date stamped Fuchs wheels
    - Pepita-colored matching custom Italian luggage and accessories
    - Porsche Classic detail bag and luggage straps
    - California emissions window decal
    - Extensive service receipts
    - Owner's manual, warranty booklet, jack and tool kit
    - Porsche Certificate of Authenticity
    This beautiful 1973 Porsche 911T is a numbers-matching car that has been restored to an extremely high standard. The color combination is absolutely stunning in its Gulf Blue body with a black leatherette interior, contrasted by Pepita Houndstooth cloth inserts on the seats. Purchased new at the famous Vasek Polak dealership in Hermosa Beach, California, this car has remained in the Golden State for its entire 43-year life with just three loving owners. The second owner was Betty Madden—a costume designer for Paramount Studios—who owned the car for 34 years and was fastidious in the maintenance and care of her 911T. The current owner appreciated the originality and the condition of the car and deemed it to be the ideal foundation for a comprehensive restoration. The year 1973 is regarded by many knowledgeable enthusiasts to be a landmark of Porsche production. It was the very last year of the long-hood/small-bumper style of 911 that would be replaced by the short-hood/big-bumper cars starting in 1974. It was the recipient of a plethora of both large and small improvements that took place since the 911 first appeared in 1964 and yet it still retained the original classic body shape features. This car was ordered with a number of desirable options including Carello fog lamps, Blaupunkt radio, Fuchs alloy wheels and exterior appearance group. This 911T is documented with the original sales invoice, service records while under the custodianship of Betty Madden and a full pictorial/invoice-history file during its restoration. The Porsche also comes with a set of custom-made fitted luggage in matching houndstooth, the owner’s manual, warranty booklet, tool kit, jack, spare assembly and a Porsche Certificate of Authenticity.
    Doug Dill
    1973 911E Coupe
    PCA #1987109761
  9. #1479
    Apr 2011
    SF Bay Area, CA
    Now posted on The Bird for $59,500: http://forums.pelicanparts.com/porsc...alifornia.html
    Quote Originally Posted by kp.sfo View Post
    1973 911T Coupe - $55k
    gemini blue
    http://losangeles.craigslist.org/sfv...651531552.html
    Attachment 384232
    Seller's ad:
    VIN: ??
  10. #1480
    FS: @Russo and Steele Monterey - 1971 Porsche 911T “Survivor” Coupe
    Russo and Steele Monterey 2016 Auction
    VIN: 9111100842
    Engine: 6115885
    Trans: n/a
    Color: Gold Metallic (88)/Black Leatherette (11)
    Mileage: -
    Auction Estimate: -
    Sold for: NO SALE recorded
    This 1971 Porsche 911T is a one-owner, incredibly original survivor car with its original Gold Metallic paint. The car retains its original numbers-matching motor and comes with the original window sticker, books, service maintenance books and stamps, tools, and Porsche Certificate of Authenticity confirming original data. Factory options listed on the CoA include antenna with loudspeaker, noise suppression, comfort equipment, tinted glass all around, and light alloy 14-inch wheels. As offered, it marks a great find for Porsche fans and collectors.
    Doug Dill
    1973 911E Coupe
    PCA #1987109761
  1. 911T Cars for Sale
    By Soterik in forum General Info
    Last Post: 11-22-2013, 07:23 AM
  2. fuel systen on 911T cars
    By motogman in forum General Info
    Last Post: 10-11-2013, 04:14 PM
  3. 1968-69 911T/R race cars?
    By jbronsonl in forum General Info
    Last Post: 05-12-2013, 08:32 PM
  4. 1965 911 Cars For Sale
    By 72targa in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 06-18-2009, 11:02 AM
  5. Cars for sale postings
    By SyarMotorsport in forum General Info
    Last Post: 12-26-2007, 09:44 PM
Tags for this Thread
