Peter Kane
'72 911S Targa
Now on eBay...
https://www.ebay.com/itm/184600655239
Peter Kane
'72 911S Targa
Peter Kane
'72 911S Targa
Bring-a-Trailer Website Auction
1973 Porsche 2.4L 911T Coupe, Lot #41877
VIN: 9113102447
Engine: 6134539
Trans: -
Color: Red (originally Tangerine)/Beige-Tan Leatherette
Mileage: 26,640 (indicated)
Auction Estimate: -
Sold for: TBD
BaT Description:
This 1973 Porsche 911T coupe was reportedly delivered new to a US service member in Europe on April 17, 1973 and was acquired by the seller approximately 12 years ago. The car is finished in red over tan vinyl and is powered by a 2.4-liter flat-six paired with a five-speed manual transaxle. Features include chrome trim, front and rear bumperettes, dual side-view mirrors, an Alpine cassette stereo, Kettering ignition, a sport muffler, SSI heat exchangers, and 15” cookie cutter wheels. Work in 2020 reportedly included overhauling the brakes, refreshing the fuel delivery system, replacing the carpets, and partially resealing the engine. This 911T is now being offered with service records from current and past ownership, and a clean Michigan title in the seller’s name.
Originally finished in Tangerine, the body was reportedly repainted in red during previous ownership. The hood and deck lid struts have reportedly been replaced, and features include chrome trim and side-view mirrors, black horn grilles, US-spec “sugar scoop” headlight trim rings, and black rubber bumperettes. The seller notes that the left front bumperette is cracked, and reports that the driver-side front fender and hood were replaced under previous ownership following damage from vandalism.
The 15” cookie cutter wheels are wrapped in 195/65 Widetrack SR tires that should be replaced due to age. The seller reports that the brakes were overhauled over the last year with a rebuilt master cylinder and calipers as well as replacement hoses and hard lines.
The cabin features tan vinyl-upholstered bucket seats reportedly sourced from a 911SC along with a black dashboard, tan door panels, and replacement carpets. An alarm system and Alpine cassette stereo are fitted, and the seller states that the A/C compressor has been removed. Noted issues include cracks in the dash and sagging door pockets. Photos showing the floors with the seats and carpets removed are viewable in the gallery.
A leather-wrapped four-spoke steering wheel fronts a suite of VDO instrumentation including a rebuilt 8k-rpm tachometer, a 150-mph speedometer, an analog clock, and auxiliary gauges. The five-digit odometer shows just over 26k miles, approximately 2k of which have been added by the seller over the last 12 years. Total mileage is unknown.
The 2.4-liter flat-six features Bosch CIS fuel injection and was reportedly rebuilt under previous ownership and fitted with Kettering ignition, a sport muffler, a fuel pump cutoff switch, pop-off valve, SSI heat exchangers, and hydraulic chain tensioners. The seller reports that the fuel injectors, pump, fuel distributor, and cold-start valve have been cleaned, and the fuel system has been refreshed with a rebuilt warm-up regulator, and a replacement pressure accumulator, injector seals, and fuel lines. The results of a compression test and fuel injector tests can be seen in the gallery, and a video of the fuel injector test can be viewed here. additional replacement parts in the last year are said to include the following:
- Oil return tubes and seals
- Breather cover gasket
- Wilwood valve cover gaskets
- Lower Turbo valve covers
- Alternator belt
- Spark plugs
- Battery
Engine stamping *6134539* is shown, and matches the number written in the factory maintenance booklet. Power is sent to the rear wheels through a five-speed manual transaxle. The seller reports that the clutch cable, transmission shift rod seal, shifter bushing cup, and shift coupler bushings have been replaced. Additional underbody images are provided in the gallery.
Doug Dill
1973 911E Coupe
PCA #1987109761
Early 911S Registry #548
The red 73 needs some TLC and maybe a color change back...but, maybe it ends up a deal for someone.
September 2020 - Listed at Driver Source for US$74,250
Driver Source, Houston, Texas
1970 Porsche 2.2L 911T Coupe
VIN: 9110101325
Engine: 6108289
Trans: 7200801 (Sportomatic)
Color: Silver Metallic/Black Leather
Mileage: 56,208 (indicated)
Price: US$69,750
Doug Dill
1973 911E Coupe
PCA #1987109761
9111111112
There's a lot going on there, between the body conversion and the engine compartment...
https://www.ebay.com/itm/274339014698
9110123204
My 1970 911T for sale on BaT:
https://bringatrailer.com/listing/19...911t-coupe-21/
David Nelson
1970 911T
1995 911 Carrera
Doug Dill
1973 911E Coupe
PCA #1987109761
PCA Online Classified Ads
1971 Porsche 2.2L 911T Targa, Ad #48628
VIN: 9111111003
Engine: -
Trans: -
Color: Irish Green/Black
Mileage: 150,000 (claimed)
Price: US$65,000 (Reduced to US$55,000 - 05/01/2021)
Seller's Description:
I have owned this car since 1995, and have kept all receipts. 150,000 miles. Engine rebuilt 70K ago , and transmission also rebuilt then. New Clutch 5K ago. Very little rust, good brakes, and all parts interior and exterior are in place. Very original. Paint a good looker at 10 feet, but there are flaws, and that is holding this car back from being a 2. Clean, well cared for, never driven in salt while in my possession, solid and straight body. Becker Europa radio.
Doug Dill
1973 911E Coupe
PCA #1987109761
