Thread: pop window sealer
    pop window sealer
    Guys,
    I am replacing the rubber seal (between the glass and anodized Frame) in the rear pop windows. What is the black goo between the seal and the frame? It was especially thick around the 'L' corner brackets when I took the window appart. Where do I get it? Or do I even need it for a car that will only get wet when washed?
    Thanks.
    73 911 S with sporto and 69 912 in rehab
    Dec 2004
    black goo may be seam sealer/body putty
    Seam sealer is a thick material (oatmeal like stuff) that is brushed on in areas to fill voids nad seal gaps. The stuff you found is most likely body putty. This putty is a dough/clay like material used for the same pruposes. Both can be found at your local body and paint store. The putty also comes in a couple of colors, off white and black. There may be other colors too but these are all I;m familiar with. The putty is used in the areas you mentioned and also around some of the gaps where the window frame and door meet.
    [SIGPIC][/SIGPIC]
    1967 911S Coupe
    1991 944S2 Coupe
    Past projects:
    1967 912 Coupe
    1969 911T Coupe
    1985.5 944 SR Coupe
    Senior Member Neunelfer's Avatar
    Dec 2002
    Sandy, Utah
    I didn't see any on my windows but I've had experience with it in my 914-6 rear window and under some door seal flashing.
    Butyl Tape. You can get it at NAPA. It comes rolled up like tape but, you can pull off what you need and it's malleable like putty (VERY sticky though)
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    80 VW “Caddy” Pickup
    72 R75/5 Toaster Tank
    PMB Performance
    Love Us On Facebook
    Guys,
    The black goo is stuff that I think was put in at the factory. I found it when I took the pop out window apart to replace the seals and also replace the clear glass with tinted glass from a parts car. The stuff is more like fender to body putty than seam sealer. I figure that it was put in at the factory like plumbers putty in a sink drain to fill any air holes.
    For the moment, the major challenge is getting the anodized trim pieces screwed back together. The rubber trim piece seems to take a lot of compressing.
    Dec 2002
    Sandy, Utah
    butyl tape
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    PMB Performance
    Love Us On Facebook
  1. Replies: 4
    Last Post: 10-09-2011, 02:09 PM
  2. Seam sealer application pics
    By MY911S in forum Technical Info
    Last Post: 09-24-2011, 01:17 PM
  3. Seam sealer
    Last Post: 03-05-2007, 07:43 AM
  4. Is it ok to use gasket sealer on lower valve covers?
    By zmayne in forum Technical Info
    Last Post: 11-03-2005, 10:02 AM
  5. Help with Underbody sealer- Wurth
    By Paul Hatfield in forum Technical Info
    Last Post: 10-27-2005, 09:39 AM
