Results 1 to 10 of 10
Thread: Backfiring with Black Smoke
    Question Backfiring with Black Smoke
    I brought my '72 911 to my mechanic for routine maintenance...oil and filter change, ignition tuning, tire rotation, valve adjustment, etc. I also asked them to adjust the MFI because although the car was running strong, I suspected it was set too rich since the tail pipe always had a lot of carbon buildup. Also, full acceleration would occasionally result in a belch of black crud out the tailpipe.
    The shop is reputable, with lots of experience working on mostly Porsches of various vintages. In fact, they've been caring for my '72 since I acquired it couple of years ago.
    In addition to the routine maintenance, they replaced the Thermo-Time Switch. After wrapping up all of the maintenance, the car sat in their shop for the next two days. When they went to start it, it cranked but wouldn't fire. After troubleshooting, they determined the switch had failed and replaced it.
    Well, I picked it up today, and immediatley noticed a difference in the way it's running. Acceleration doesn't seem as strong and crisp as before, while a couple of full throttle bursts out on the freeway produced 2-3 loud backfires with a significant puff of black smoke each time. While driving in town, it also produces a sporatic "popping" sound. These are not as violent as the full throttle backfires, however, they're still audible.
    So, my question is, what do you guys suspect is causing this? Mal-adjusted MFI, or ?????
    Frank
    Cheers!
    Frank Kohnen
    Jupiter, FL USA
    Registry Member #921
    1972 Bahia Red 911 Coupe #9112100390..."Rudy" SOLD
    1967 Savannah Beige VW Beetle Sedan #117364457..."Heidi"...aka "Tinker Toy"
    I had a similar problem: backfiring, bad idle, cutting out during "full throttle bursts". I bought an LM-1 and immediately discovered the MFI was set way too rich. Dialed it back and it run quite nicely. YMMV
    Greg DuPertuis
    1972 911T
    Leesburg, VA
    Quote Originally Posted by rs911t
    Thanks Greg. What is an "LM-1"?
    Frank
    ps: Glad to see you've hung on to your '72. That is one beautiful 911!
    Cheers!
    Frank Kohnen
    Jupiter, FL USA
    It's an wideband air/fuel ratio meter. See http://www.innovatemotorsports.com/products/lm1.php
    Greg DuPertuis
    1972 911T
    Leesburg, VA
    '72 911T 3,0 liter MFI Albert Blue street/DE toy Jeff Higgins's Avatar
    Jul 2006
    Lynnwood, WA
    I would ask the shop specifically what they adjusted on the MFI. The high speed mixture is where most would turn to "adjust" it, and possibly the low speed. If they leaned this out significantly, that may very well be the problem.
    Your big cloud of black smoke on acceleration is charictaristic of MFI, as is the black soot in the tailpipes. Especially if you have been cruising for an extended period at lower rpm's, or puttering around in traffic, they will all "clear their throat" with a pretty good black cloud the first time you open it up. It should clear up after that, and stay clear as long as you are running it hard. Any effort to "remedy" this may result in a lean condition.
    One other oft overlooked area is the spark plugs. Because of the rich, sooty environment in which they run in an MFI motor, the fancy whiz-bang plugs don't seem to survive. Any of the new designs with the thin wire, or multiple wire electrodes seem to foul very quickly. If your shop "upgraded" to something like this, that might be the problem. MFI likes the old style, fat electrode, cheap plugs. I run NGK BP7ES or BP8ES's.
    "God invented whisky so the Irish wouldn't rule the world."
    Thank You
    Thanks for the tips Jeff.
    I dropped the car off at a different shop (http://www.early911sregistry.org/for...ad.php?t=16187) yesterday. They reported today that after some minor MFI adjustments, it's running "quite nicely now". They did a bit more fine adjustments this am, and plan to do a final check first thing tomorrow am.
    I can't wait to take it out for a nice long run this weekend!
    Cheers!
    Frank Kohnen
    Jupiter, FL USA
    Quote Originally Posted by FL-Frank
    It's just about impossible to get a tailpipe that isn't black these days. The fuel we use doesn't do the "gray-brown" burn. I'll admit that if you were spewing black smoke your car was indeed running "fat".
    If you want to experiment try some racing fuel. I use a C12 (which does contain lead). My car sits a lot. These types of fuels do not break down as easily as pump gas which is pretty much history after 2-3 months. MS101 is a very good no lead fuel.
    All of these are available from VP Racing Fuels.
    http://www.vpracingfuels.com/vp_10_techdata.html
    Tom
    Early S Registry #235
    rgruppe #111
    If you want to experiment try some racing fuel. I've used C12 (which does contain lead). If a car, motorcycle or any engine for that matter sits a lot you will have issues with fuel break down. My car sits a lot. These types of fuels do not break down as easily as pump gas which is pretty much history after 2-3 months. I have never had any issues with a vehicle sitting up for extended periods with this "good stuff" in the tank.
    Tom
    rgruppe #111
    Nick D member #403 nickd's Avatar
    Jul 2005
    Landenberg, PA
    racing fuel
    I pop in about a gallon of leaded race fuel to 10 to 15 gallons of unleaded street fuel - them pipes go nice a grey after a run. I was told that the lead lubricates the mfi unit some while back and it sure does run better.
    my 2 cents worth
    Nick D - Run Flat
    1973 RHD 911 Carrera RS #0358 - Fun Car
    2016 Cayenne Diesel - Tow Car
    2017 Macan S - Better Half's Car
    1955 356 Speedster SOLD
    1976 911 2.7 SOLD
    2006 Cayman S SOLD
    2006 Cayenne S SOLD
    2008 Carrera S F77 SOLD
    2011 Cayenne S TOTALLED (T-Boned but kept us safe)
    2015 Macan S SOLD
    2015 GT3 - Track Car
    2016 Cayenne SOLD
    2016 Cayenne GTS TOTALLED (Bloody big deer)
    Still looking for 1st Edition Carrera RS book #358.
    Life is way too short to drive boring cars.
    Thumbs up Wow! What a difference!
    Description of Service:
    Checked timing, adjusted points, repaired electrical contact on distributor, adjusted injection pump (low speed), checked throttle body calibration, test drove, re-adjusted cold CO values, final test drive. 3.5 Hours.
    I can't believe it's the same car! It's smooth as silk and pulls real strong now, without any backfires or pops or any black smoke at all!
    Many thanks to Bruce and the guys at KSR!
    Cheers!
    Frank Kohnen
    Jupiter, FL USA
  1. 70t engine question, backfiring at 80 mph+
    By Surf65 in forum Technical Info
    Last Post: 02-25-2012, 01:01 PM
  2. MFI Backfiring
    By 50/50 in forum Technical Info
    Last Post: 07-11-2011, 08:18 PM
  3. What's causing the slight backfiring
    By FL-Frank in forum Technical Info
    Last Post: 07-13-2009, 06:34 AM
  4. Bad Gasoline = Backfiring?
    Last Post: 02-09-2006, 07:48 AM
  5. Backfiring
    By ereed27 in forum Technical Info
    Last Post: 09-20-2005, 10:13 PM
