Thread: Replacing all front bushings on 73 E
    Aug 2005
    VA
    Smile Replacing all front bushings on 73 E
    All the front bushings on my 73E are original. I bought Turbo tie-rods and figure I should replace all the front bushings while I am in there. I did the rear a year ago with great success.
    Can someone tell me what I need? Looking for a slight upgrade in performance over the stock bushings but not an all out race set up.
    Chris
    73 911 E
    Senior Member Neunelfer's Avatar
    Dec 2002
    Sandy, Utah
    www.elephantracing.com Go with these...
    The Daystar bushings that are on the market are well covered on most forums. They can be noisey and can lend to serious suspension problems (check with Dave at TRE for an example).
    Chuck's bushings (Elephant) will "not" give a harsh ride and they will probably last as long as the one's that you're now taking off.
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    80 VW “Caddy” Pickup
    72 R75/5 Toaster Tank
    PMB Performance
    Love Us On Facebook
    Aug 2003
    Van Nuys, Ca
    Yep- we are quite pleased with the Elephant racing line of bushings. Remember to periodically grease them
    All the plastic ones fall under the "Squeakmeister" category! They deform too easily and bind up
    Member #755
    Conda Green 70 911S
    70 black 914-6 3.2
    70 911 "Speedster" project
    "74 IROC" tribute Jade Green RSR
    Aug 2005
    VA
    Thanks for the link. Are the only bushings I need the ones replaced by the PolyBronz control arm bearing? I thought there were others (on both ends of the front T bars for example.
    I have never taken this end of the car apart so don't know what's in there.
    Sorry for the ignorance.
    Thanks in advance.
    Chris
    73 911E
    Chris, you'll need the bushings at each end of the t-bars, the bushings for the through-the-body sway bar, and the bushings for the sway bar drop links.
    Jim Richards
    Aubergine 1973 911E Sunroof Coupe w/ 2.7RS MFI
    Early 911S Registry Member #589
    GruppeB #911
  1. replacing front discs - 73 's' - torque settings
    Last Post: 04-01-2014, 09:01 PM
  2. Replacing front bumper deco
    By Zuffenhausen in forum Technical Info
    Last Post: 01-20-2011, 09:05 AM
  3. SWB help please - what bushings for front A arms?
    By haycait911 in forum Technical Info
    Last Post: 01-10-2010, 04:27 PM
  4. Questions on front A arm bushings
    By Allen Henderson in forum General Info
    Last Post: 10-31-2007, 06:57 PM
  5. Replacing Front Bumper Seal - DIY
    By TEC69E in forum Technical Info
    Last Post: 06-05-2007, 05:26 PM
