Thread: Ignition Overhaul - Need Recommendations on Wires, Plugs, Points
    Aug 2006
    Chicago area
    I have decided to give my RGruppe car a tune up and valve adjust. I am going to replace the plug wires, plugs, distributor cap, rotor, and points. My questions are simple:
    What brand and type of wires have you guys used successfully for S motors?
    What brand and type of plugs work the best in your experience?
    Who has converted from the old style point system and are you happy with the result?
    I would appreciate some experienced opinions for my "hotrod" so I can make the right choices with equipment. Thanks!
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    Senior Member Grady Clay's Avatar
    Sep 2004
    Unincorporated Arapahoe County, Colorado, USA
    Scott,
    An important issue is to find someone with a Sun distributor machine. This will let you “run-in” your distributor after cleaning, rebuild and new points. An important feature is to get the distributor hot. After run-in, clean the new points.
    All the other parts are new: cap, rotor, wires, plug connectors and sparkplugs.
    A scope will tell if there is a CDI or ignition transformer issue. Make sure all the connections are clean and good. Look at Early-S-Man’s threads on Pelican.
    Best,
    Grady
    New Toy
    Scott,
    How about some info and pics on that "new toy" you scored today
    J-P
    ______________
    S Registry #949
    Aug 2006
    Chicago area
    I have no idea what you are talking about. Must be some other T6 pilot. Just kidding, I will disclose the story in due time. Now stay on topic J-P. Still looking for recommendations on my original questions.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    Scott:
    We've had excellent luck using Bosch caps and rotors, Magnecor 8.5mm wires/connectors, Bosch W4CS or NGK B7EV plugs, and either stock points or the Pertronix ignitors.
    Grady's point (no pun intended) about having your distributor checked out by someone with a Sun machine is sound advice as thats an effective way to ensure that the advance mechanism is functioning correctly.
    Hope this helps,
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
    Aug 2006
    Chicago area
    Thanks Steve. Then that is what I will go with. I appreciate the help.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
  1. Ignition wires
    By Merv in forum Technical Info
    Last Post: 05-28-2013, 02:06 PM
  2. MSD Ignition Frying My Points!
    By leadrsa729 in forum Technical Info
    Last Post: 10-28-2011, 07:39 PM
  3. Ignition Wires any difference?
    Last Post: 04-08-2009, 07:08 PM
  4. New Plugs Wires report
    By Boulder Bob in forum Technical Info
    Last Post: 08-31-2008, 05:53 AM
  5. Ignition Switch Wires
    By B D in forum Technical Info
    Last Post: 06-19-2007, 01:47 PM
