Thread: 40 IDS value??
    40 IDS value??
    Hi All
    Can anyone give me a ballpark for a pair? They are currently installed on a running engine but I think would benefit from a rebuild?
    Steve
    Good 40s that are running but not rebuilt are usually between $1200-$1400 depending on how close to a rebuild they are. I've seen beater cores for $800, but these are typically not worth rebuilding when you can find a better set.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    old softie67S
    Feb 2007
    Sanibel Fl
    ids
    I have to believe the ids are worth more than the ida 40's but have no info to prove my gut feeling
    Tom
    67S soft rear window
    60 356 Cab
    70 914-6 3.2 short stroke twin plug
    05 Audi S4 Cabrio (commuter)
    05 Audi Alroad (family driver)
    Aprilia SR 50R (Sanibel scoot)
    you'd think so, but I've never seen a difference. this may be because folks don't know the difference, but is also likely because the enrichment circuit didn't really work.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Re IDS value
    Thanks for your input guys
    Steve
