Results 1 to 8 of 8
Thread: Some Rare Early Engine Parts
    I'm trying to clean up the garage to start my restoration project - target date is to start at the end of August, so that gives me a month to get stuff out of here.
    I've recently taken apart a couple early engines and have the following parts available:
    1) Front chain cases and covers for solex centre lube cams - $250/pr
    2) Early distributor - surface rust on outside, but seems to be ok - $75 **SOLD**
    3) Early sandcast aluminum fan housing, fan and altermnator - good shape, but casting number is a bit blurry - not sure if alternator works - $375 **SOLD**
    4) Early sandcast aluminum upepr valve covers - $75/pr **SOLD**
    5) Early sandcast aluminum 6-bolt lower valve covers - $75/pr
    Chain
    6) Very early cam towers for centerlube cams (no spray bar, 6-stud lower cover arrangement) - $150/pr
    7) Early cam towers for later cams - spray bar for oiling, but still 6 stud lower cover setup - $130/pr **SOLD**
    8) Centerlube Solex cams - could use a light refinish / polish - $225/pr
    9) Set of early forged adjustable rockers set of 12 rockers (I'll include the early shafts and early bolts as well if desired) - $340/ set of 12 **SOLD**
    All prices are + shippping and I accept paypal.
    I'm sure there is more, but this will get the clean out started.
    Andrew M
    Andrew,
    Sent you a pm on the following:
    --mike
    Senior Member 72tii's Avatar
    Nov 2004
    Bedford, TX
    I'll take the distributor if it is still available. Let me know the total to zip code 76021.
    Mike
    1968 911 #11830241
    Early S Registry #810
    R Gruppe #461
    valve covers
    PM sent about upper valve covers
    72tii/Mike - There is one person looking at the distributor, I'll let you know if he doesn't take it.
    Nov 2004
    Bedford, TX
    Quote Originally Posted by andrew15
    Sounds good- I'll take it the other guy passes.
    1968 911 #11830241
    R Gruppe #461
    Mar 2004
    Twin cities minnesota
    cam towers
    If the cam towers are stll available I'll take them. Kevin
    Sent you an e-mail about the rocker arms, etc.
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
  1. Early 911 rare parts MFI/CDI/Oil Tanks
    By pkg911 in forum For Sale: 911 Parts
    Last Post: 11-08-2009, 07:39 PM
  2. FS Many rare and wonderful early 911 parts
    By 69S-S/R in forum For Sale: 911 Parts
    Last Post: 01-26-2009, 03:02 PM
  3. Rare early parts. Most NOS
    By Rennman in forum For Sale: 911 Parts
    Last Post: 03-16-2008, 06:05 PM
  4. Rare Early 911 2.0L Engine Parts
    By Porsche Doc in forum For Sale: 911 Parts
    Last Post: 01-19-2006, 06:56 PM
