Thread: 67 S matching numbers info
    I saw a thread where I can match up other members cars for a sequence on the numbers to see if numbers are in the right number area.
    this car VIN #307065S has engine number 960981 code 901/02
    appears to be original.
    I seem to remember that was maybe in print...the Esses maybe?
    cant quite recall....
    Thanks a bunch
    Z
    Richard aka le Zookeeper
    early reg #1128
    Number sequence's
    Is this the one? It's under the http://www.early911sregistry.org/for...t=12939&page=7
    Thanks guys. This list is again filling in nicely. With your info, it's turning into something very special.
    1965 Year of Mfg.
    Chassis ......Engine......Trans....Color Code....Build Date../..Model Year
    300235.......900347.....100240.................... .4 Jan 1965/1965
    300266.......900368.....100285...................1 1 Jan 1965/1965...
    300376.......900530.....100496...................2 7 Jan 1965/1965...
    300398.......900475.....100371.................... .1 Feb 1965/1965
    300401............................................ ..........1 Feb 1965/1965....Switzerland
    300675
    300688.......900828.....100728.................... 18 Mar 1965/1965.."911quest"
    300703
    300720
    300845............................................ ........................................John Clinard
    300882
    300898............................................ .....................1965/1965 ..Paul Henninge
    300941............................................ ...................................... France
    300953............................................ .......................................Mike Olson
    301021
    301111......901277......101190.....6405..........A pril 1965/1965.. John Straub
    301172......901236................................ .................................EurosportCA
    301134
    301278.....901428......101349......6411........... .............../1965...”Carsngolf”
    301354............................................ ........................................
    301358............................................ ........................................Austria
    301368......901484......101406.....6411... ....25 May 1965/1965.."DaveE"
    301382......901505......................6405...... .21 Jun 1965/1965.. Jim Alton*
    301606
    301612
    301620............................................ ...................................Gloucester, VA
    301621............................................ .................................. France
    301759............................................ ...................................Holland
    301803.......902010............................... .....20 July 1965/1965 "marinmccreevy"
    301807
    301814............................................ ....................................David Hedderly-Smith
    301826.......901936.....................6206...... .................../1966. John Ashford
    301836
    301858.......900661.....................6407...... ................................benman0034
    301879.......901919......101857.....6412.......21 July 1965/1965. Baltimore, USA
    301911
    301932............................................ .........................................Jack Troup
    301940 ......901967......................6401............ July 1965/1965 ......David "LGK6D" *RHD
    301945. .....902097.....102019......6606.......27 Aug 1965/1966... "Richard-304678"
    302064.......902158.....102075......6404.......... .............. /1966(COA)..Belguim
    302129
    302138.......................................6602. ......................../1966 ..”Kenaichoochoo”
    302413............................................ ..............Sep 1965/1966 ..Sigurdson
    302646.......900420............................... ..................................Frank Bennallack
    302831............................................ ..........12 Nov 1965/........"semjon"
    302861............................................ ......................................Belgium
    302933............................................ ......................................Rick Cabell
    302943. ......902965....................6602.............. .........../1966 "KStens"
    302947........903154....................6602 ..... 25 Nov 1965/........."in LA
    302981........903143......225230....6608.......24 Nov 1965/1966(COA)R.Schneider
    303056........903279......225903.................. .14Dec 1965/..........East Coast
    303129........903235......225591.................. ..1 Dec 1965/1965 (COA) JHunter
    1966 Year of Mfg.
    303382............................................ ........................../1966....E.Pederson
    303391
    303414............................................ .........................../1966...."roblav"
    303448............................................ ................................... Switzerland
    303734
    303941.......................................6206. ................................benman0034
    303997.........907276............................. ..................../1966...Rick Cabell
    304010.......................................6604. ....................../ 1966..Nix0807
    304065.........907316.....229641....6606........1A pr 1966/1966(COA)J.Cramer
    304761............................................ .................................. France
    304784.........908024............................. .............1966/1967..Tim "axis 11"
    304879.........908047............................. ..................../1967..Brian "bonzo"
    305101..1967 Model / Sept 1966
    305457S......960138.......................6602.... ...Aug 1966/1967 ..Mike "210php" *RHD
    305701........909363......130300......6602........ ....................... JCF
    305809S......960281.......103282.....6206......... ......1966/1967..Fritz A. Ficke
    306956S......961030......104025................... . Dec?1966/1967..
    1967 Year of Mfg.
    307351
    7-12-07
    Bob
    Early S Reg #370
    Seattle WA
    I have the list at my office..., will update you on Monday.
    However, in the meantime, I have 307117S with engine 961001, so you've probably got the original engine, and I've got the original German Kardex.
    Eric
    Dec 2006
    Las Cruces, New Mexico
    Mine 306866, engine # 960867, transaxle 103852/ 901/02, I also have original Kardex. You are right there.
    Early 911S member #166
    Goldmember ttweed's Avatar
    La Jolla, CA
    Quote Originally Posted by EARLY911ZOO
    You might be thinking of the Registry database that Fred Trueman maintains and sends out to members every year. Last one I got was emailed in April of this year -- an Excel spreadsheet.
    Your numbers are in the ballpark, as everyone has said. There is no 1-1 correspondence of VIN and engine serial number progressions.
    TT
    #306831S w/ engine #960841
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
    yep that's it, Fred's list
    I found it in my emails
    Thanks TT
    early reg #1128
  1. 1969 911s value matching numbers vs non matching
    By frankmar in forum General Info
    Last Post: 02-26-2015, 09:53 AM
  2. Is this a numbers matching car?
    By Porscheophile in forum General Info
    Last Post: 01-21-2014, 04:04 AM
  3. How tell if a car is numbers matching?
    By therossatron in forum General Info
    Last Post: 06-16-2013, 04:55 AM
  4. Matching numbers, what does it take?
    By teveo in forum General Info
    Last Post: 08-08-2009, 11:21 AM
  5. New Guy Matching numbers?
    By wanna911s in forum General Info
    Last Post: 04-21-2008, 10:19 PM
