Thread: Pan update
    Suspension Pan update (title updated for clarity)
    No pics at the moment but will add some this evening.
    Old pan and the front foot or so of both lateral supports are removed. The lateral supports were easy to remove and worth the time/expense as i found additional acid damage on the driver side pan. It had been hiding beneath the lateral support and was terribly obvious once i had cleaned off the grime.
    The good news is i just had to remove a few more inches of pan and that is fixed. In retrospect i should not have cut the replacement pan 'arms' short before i had removed the lateral supports but i lucked out in that i had enough of the replacement pan 'arms' length to correct the area. i certainly could have just welded the cutoff portion back to the replacement pan but the less welds the better IMO.
    I also welded up some small areas where i overcut on removal of the pan/lateral supports.
    I had been dreading grinding down the metal left at the spotwelds by the spotweld cutters (can you believe i went through 5 1/2 cutter heads!) with the grinding disc but it turns out the flapper disc wheels (80 grit is what i had handy) do a fantastic job, though they generate a LOT of heat (the burn on my knee from leaning against the bulkhead is pretty small and should heal okay ).
    Pan is test fit and i need to do a bit more work to get the cuts to match up but things are moving quickly now.
    Erik
    Early S # 1107
    All my german equipment is either busted or sold...sigh....in the market for a decent non-sunroof tub!!!!!!! Help me get back to autocrossing!!!
    Senior Member karlusmagnus's Avatar
    Aug 2005
    NY
    fearless
    Erik, you are truly fearless.
    Can't wait to see it, once its all done.
    Karl.
    '72T Coupe - Sepia Brown
    Senior Member Homemade 911's Avatar
    Dec 2002
    China Lake - Third Rock From The Sun
    Please post pics...
    I'm getting ready to change out the floorpans in their entirety, on the Homemade 911.
    I'd like to see some pics of what you've done,how you went about it, and what you wouldn't do next time around...In fact, PM me, and we can exchange phone #s or private email addresses. I'd like to hear all about your experiences...
    What I'd like to do is:
    a). get my arms (and head) around this whole process, and
    b). document my own project with enough photos and intelligent writing in order to share and pass along to the rest of the early 911 world.
    Cheers
    Thom
    Homemade i'm doing the suspension pan, not the floor pans. Sorry if i was unclear.
    Erik
    Early S # 1107
    a few pics.
    Erik
    Early S # 1107
    looks great!
    good job
    bob
    bob moglia
    '72 E sunroof coupe
  1. 67S Update
    By BBausser in forum General Info
    Last Post: 04-09-2006, 10:23 AM
  2. Progress Update
    By Mr9146 in forum General Info
    Last Post: 04-07-2006, 01:59 PM
  3. DP 935 Registry update
    By cosley in forum Off Topic
    Last Post: 03-01-2006, 07:35 AM
  4. '73 S Resto Update:
    By yopurp in forum General Info
    Last Post: 01-22-2004, 05:33 AM
  5. Classified ads, update
    By admin_old in forum For Sale: 911 Parts
    Last Post: 12-02-2002, 03:16 PM
