1967 Porsche 911-S
Red Coupe - Overall Excellent condition
Maintenance records for last 16 years
All work last 9 years done by reputable Porsche shops (Andial, Aase Motors, N.A.R.W., etc.)
Detailed Condition of Vehicle
Engine
Original engine Rebuilt by previous owner
Original cams
Emulsion tubes & air jets replaced
Gas tank replaced
Ignition changed to electronic type
Fuel pump replaced
Gas pedal linkage straightened and stop adjusted
Engine mount tab broken, repaired
Carburetors are 911-L type 40-IDA-3C & -3C1, adjusted for higher delivery
Transmission
Original transmission
Clutch and seals replaced
Short shift kit removed, bushings replaced
Shift linkage tightened
Body
Repainted (to original color – Polo Red)
Rechromed
Front and rear lid shocks replaced w/ OEM
Almost all rubber gasketing replaced
Rear deck lid and grille are not original
No rust, but heat damage to rear skirt paint
Exterior rear view mirrors in wrong location
Suspension
Fuch alloy rims - polished
Suspension raised back to factory spec
Rear spring plate &
sway bar bushings replaced
Wheel bearings replaced
Trailing arm repaired
Lower ball joints replaced
Inner fork and bushings replaced
Interior
Steering wheel 1960’s era custom Nardi type
Interior lights repaired
3” red 4-point Deist harnesses installed for both Driver and passenger seats
Upgraded radio, amplifier & speakers
Seats are non-original, recaro style
Miscellaneous
Original combustion heater (disconnected)
Horn repaired
Windshield washer pump replaced
Wiper arms replaced
Tires replaced
Battery replaced
Locks rekeyed
Rotors replaced and front calipers rebuilt
Anti-Theft system installed
Clifford Concept 100
Original driver’s manual
All workshop manuals
History
Owners
1967 – 03/1991 RM Hamm & unknown prior
03/1991 – 8/1998 Phil Slate
09/1998 – current Patrick Girvin
VIN 308477S
Engine No. 962099
Contact
Patrick Girvin
Irvine, CA
(949)929-0024 cell
patrick.girvin@gmail.com
