Results 1 to 10 of 12
Thread: Fuel Filter Questions
    Presume the 1967 911S came with a fuel filter, though my car has none.
    Can anyone help with the correct location and type?
    Thanks for the help.
    Dave D.
    1967 911S SWT
    Goldmember ttweed's Avatar
    La Jolla, CA
    The filter is in the bottom of the original Bendix electric fuel pump--a replaceable screen element and a magnet for ferrous particles accessed by removing the bottom cap of the cylindrical pump.
    Is your pump original?
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
    La Jolla, CA
    Found this pic:
    Tom Tweed
    R Gruppe #232
    Read my surf novel!
    Tom:
    Your a wealth of knowledge on these cars. Thanks.
    Yes, the original pump. Glad I didnt install the aftermarket fuel filter I bought yesterday.
    Are replacement screens available for the original or can they be cleaned and reused? Anything tricky to be careful about on the removal? Does the gasket need to be replaced?
    Dave D.
    1967 911S SWT
    La Jolla, CA
    Quote Originally Posted by 67S
    Since the bendix pumps are NLA, it might be hard to find the replacement screen filters, but it's possible Facet elements might work, since they sort of copied those pumps.
    They can be serviced and cleaned, though, so if yours is undamaged, go for it. Same with the gasket (although that would be easier to replace or fabricate if necessary). Here are the repair manual instructions for that operation from just below the picture above (in typical factory underspeak):
    Tom Tweed
    R Gruppe #232
    Read my surf novel!
    Thanks again Tom.
    Dave D.
    1967 911S SWT
    Who can point out the two things wrong with the factory's photo of the Bendix pump? (Hint-- that's probably a 356 file photo)
    Metal fuel lines?
    Richard
    The sticker might be on the wrong side since when this mounts on the left side you can't see the sticker?
    Richard
    Richard wins!
    The original has banjo fittings, not straight fittings, and the bracket to mount it is located on the left side, not the right. That must be an old 356C photo or something.
  1. FS: MFI fuel console, bracket and new fuel filter
    By 911scfanatic in forum For Sale: 911 Parts
    Last Post: 03-21-2013, 04:55 PM
  2. Who was looking for an MFI fuel pump and fuel filter assembly?
    By javadog in forum For Sale: 911 Parts
    Last Post: 09-22-2011, 08:09 AM
  3. FS: MFI Fuel Filter Console and Electric Fuel Pump
    Last Post: 07-28-2008, 07:10 AM
  4. Fuel filter ?
    By zaza in forum Technical Info
    Last Post: 02-12-2005, 09:53 AM
