Thread: VIN numbers and dash rail numbers
    Hello all.
    Please could someone help decipher these?
    I have a 1969 E body which has the VIN defaced and illegible..but the body build number in the dash is intact...
    I know these are closely correlated..but not exactly how.
    I need to find the VIN to trace the car's origins and check its not stolen..
    Kind regards
    Jan 2003
    UK
    There is no direct relationship between the production number & the VIN for lwb models (for earlier swb models the number was the same as the VIN) - in other words you can't determine the VIN (or even whether the car is a T E or S variant)from the production number.
    All you can determine is whether it is a Coupe or Targa & what the model year was - a '69 coupe's productiojn number will be in the format:
    109XXXX
    '1' is for 911
    '0' is for coupe (1 would be for Targa; and I think a 2 is for Karmann coupe)
    '9' is for '69 ('0' for '70, etc)
    'XXXX' is a consecutive # for the shells being produced.
    __________________
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Thanks, Andy.
    Very helpful..
    I do know that it MAY be possible..tho' I do not know exactly how or whether it comes from some factory or importer's records..rather than by "processing" the body number itself....
    I will ask PUK..(AFN)....its a RHD car..
    Kind regards
    Jan 2003
    UK
    Only Porsche themselves will know the relationship between the 2 sets of numbers.
    If you quote both numbers for a specific car they will tell you if they match or not but if you only have one of these numbers they will not divulge the other one.
    Andy
    Early 911S Reg #753
    R Gruppe #105
  1. Porsche Part Numbers to Bosch Part Numbers
    By FL-Frank in forum General Info
    Last Post: 06-28-2009, 08:56 PM
  2. Numbers numbers again...
    By BlutorangeS in forum Technical Info
    Last Post: 10-09-2008, 10:31 AM
  3. vin and engine numbers
    By ferry58 in forum Technical Info
    Last Post: 11-14-2007, 08:26 AM
  4. Help with numbers
    By gilbert911 in forum General Info
    Last Post: 06-21-2007, 07:07 AM
  5. 67 s numbers ?
    By southbay356 in forum General Info
    Last Post: 04-24-2006, 01:49 PM
