Thread: Fuel combo gauge ?
    David Sperow Davz912/911's Avatar
    Sep 2006
    South San Francisco
    Fuel combo gauge ?
    Couple of questions, as I continue on the conversion to "S" gauges on my 911 clone . Does the fuel gauge / oil level instrument have a low fuel light like the standard fuel gauge? Since my car started life as a 912 would there be a wire "tied down" for the oil level gauge? I have seen a green
    wire floating around in there with no place to go....could this be it?
    Thanks in advance
    Dave
    911S registry #1103
    R-Gruppe #513
    1967 912 converted to 2.2
    Period Dune Buggy
    Some drive Porsches' to be seen.....
    I prefer it when nobodys looking.
    I have the combo S gauge on my 73S and 71T, both have a light for low fuel level. Cant help with the wiring, sorry.
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    combo gauge
    I can't remember if the 912 used the low fuel light, although I see no reason why it wouldn't have, but I am pretty certain the 912 and 911 shared wire harnesses. The oil level sending unit wire is green with a white tracer, the wire to the fuel level sender is just green. If the oil level sender wire is in the harness I would expect the other end to be taped up behind the right rear light unit.
    Sep 2006
    South San Francisco
    Thanks Ed
    The fuel gauge in there now does have a low fuel light, large and red @6 o'clock position. Thanks for the tip on the tank wire, I'll look for it.
    Cheers,
    Dave
    911S registry #1103
    R-Gruppe #513
    Period Dune Buggy
    Jan 2007
    North of the GG Bridge
    I know that the 912 has an unused wire for the 911 oil pressure gauge. It is usually bundled about in the middle of the firewall in front of the motor (green/red?).
    Sep 2006
    South San Francisco
    Ok
    Found the harness, thanks Ed, now, how/where does it go through the fender
    well? I see no pluged hole, does it follow one of the oil hoses? Next question, on the gauge side, green/white goes to the "G" side, but what about the "+" side?
    Found and printed a schematic, and am thinking Blue w/yellow?
    Dave
    911S registry #1103
    R-Gruppe #513
    Period Dune Buggy
  1. Replies: 3
    Last Post: 04-09-2014, 02:23 AM
  2. '68 Normal Sporto Combo Gauge Wiring Question
    By JT912 in forum Technical Info
    Last Post: 04-04-2013, 08:49 PM
  3. WTB Oil Temp/Oil Preassure Combo Gauge -1968
    By hoffman912 in forum For Sale: 911 Parts
    Last Post: 01-16-2012, 09:48 AM
  4. Very early green face combo gauge
    By 9seriesguy in forum For Sale: 911 Parts
    Last Post: 11-07-2011, 09:20 PM
  5. FS- '68 911L 911S Fuel/Oil Combo Gauge
    By 72tii in forum For Sale: 911 Parts
    Last Post: 08-06-2010, 07:04 PM
