Thread: Bilstein strut spindle thread size issue
    I bought a new set of Bilstein front struts with the 3.5" spacing for the S calipers. The problem I am having is the Spindle threads are now larger than before, I found the larger U-shaped spindle allen wrench clamp that holds the hub on but it won't fit inside the brake drum hub. Can I buy later hubs? What to do? Thanks Ron
    Aug 2007
    The Woodlands, TX
    I did a '72s+ Bilstein coilover conversion on my '71 and retained the original hubs. Had to get the larger diameter allen-clamp nut for the original '71 Boge spindle nut was too small. I believe it is the difference between a 16mm and an 18mm nut. What year are your hubs? The larger nut fit (but tight) in the hubs which I believe are original. If barely not able to fit, you can probably file down the arches of the nut/thread end to make clearance? A SMALL amount of removed material on the extreme edges should'nt compromise the nut integrity.
    -Mike
    EarlyS #1320
    '71 T/RS LWT 3.2L
    hubs
    The car is a 73 and the hubs are from the same car. Thanks for the suggestion, I will take a look at that tommorow
  1. Replies: 4
    Last Post: 03-07-2014, 06:18 AM
  2. FS: Brand New 3.5 Bilstein Strut Right side
    By dporsche74 in forum For Sale: 911 Parts
    Last Post: 09-24-2013, 12:55 PM
  3. Roll pin size for Bilstein strut ?
    By RS-GT in forum Technical Info
    Last Post: 09-03-2012, 02:14 AM
  4. Bilstein strut insert replacement
    By NickP in forum Technical Info
    Last Post: 08-04-2009, 12:04 PM
  5. FS: Bilstein strut housings
    Last Post: 04-03-2009, 01:14 PM
