Does anyone know what technique the factory used to achieve this finish on their more exotic engines? Is it the coating that Dow makes?
edit: Sorry, I meant for this to be in off topic.
'74 leichtbau
"Sascha"
R Grp 246
S Reg 823
Jim,
That brown color is characteristic of a process known, alternatively, as "Dow 7" or "Alodine" or "Iridite." It is a conversion coating that works only on Magnesium. This is why you only see it on exotic stuff like 917, 906, etc.
Hope this helps. It would not be correct for 911 stuff.
Thanks John. I was just curious if that was what the Dow process looked like on Mg. I wonder how it would hold up on Mg wheels? Probably not great.
'74 leichtbau
"Sascha"
R Grp 246
S Reg 823
Jim,
It would be better from a corrosion and appearance standpoint to first apply the conversion coating and then topcoat with paint or another finish. In the case of something like a fan, a coating such as electroless nickel might fare better over the long term.
I think that Dow 7 was invented for magnesium aircraft wheels.Originally Posted by Jim Garfield
Tom F.
Long Beach, CA
Originally Posted by Tom F.
Hmmm, that's interesting. I can see that I'm going to have to do some research about the process. I remember reading about it years ago but I don't recall many of the details. I wonder why Porsche didn't use it on all of the Mg bits?
'74 leichtbau
"Sascha"
R Grp 246
S Reg 823
... like my 901 gearbox case which is beginning to approach the porosity of a sea sponge
Seriously, is there any reason why you couldn't do the exterior of an entire gear box or engine case? It would sure be the solution of old minilite wheels and coke bottle wheels that are getting nasty at this point.
This image is of a freshly treated magnesium 915:
Early 911S Registry
Looking for engine 960 168
Looking for gear box 103 165
Treated with what?Originally Posted by Flunder
Tom F.
Long Beach, CA
