I am looking for the u shaped sheetmetal reciever that is welded to the floor of the front trunk to receive the washer bottle on a 67 911. I think it is NLA. Anyone have a rusty hulk with this part? tom
Tom
67S soft rear window
60 356 Cab
70 914-6 3.2 short stroke twin plug
05 Audi S4 Cabrio (commuter)
05 Audi Alroad (family driver)
Aprilia SR 50R (Sanibel scoot)
If by chance you find two of these I am also looking for one.
With thanks
Alan
Alois Ruf sent along this photos from a 67S he was restoring to show placement of the washer pump but it also shows the Washer bottle stand. It is a strap bent to shape and spot welded in place.
I made a repro stand for my car - and could make more, would you like a pattern and dimensions for that stand or are you interested in having the repro part?
Bob
Early S Reg #370
Hi Bob, I would be interested in obtaining the correct dimensions as looking at that one I think I will make one and spot weld it in.
Alan
Hi Bob,
Thank you so much for responding. I would buy the peice if you can create one or would gladly take a pattern if that is more convenient.
Is that the correct position of the washer pump? I just looked at a very original 67 that had it's mounting holes in a different location? Any other pictures or comments on the washer pump location.
tom
Tom
60 356 Cab
Tom and Allen
here are the dimensions and photos of the repro bracket. I had a chance to put it next to another car prior to welding it in and it in a matched shape for the factory part.
The bracket is somewhat centered below the two bottle screw mounting holes in the above latch panel. See the Ruf photo above.
Let me know if this works for you.
Anyone have a source for the felt pad that rides between the bracket and the bottle?
Bob
Early S Reg #370
thanks Bob
In my search for the sheet metal part, I saw the felt. I just checked a few locations looking for the felt but cant find it. I will post as soon as I find it. thank you. tom
Tom
60 356 Cab
Thats great Bob, thanks very much.
Alan
Tom,
I have one. Check your PM.
Thomas
