Results 1 to 10 of 18
Thread: Engine out of the car in 1.5 hours
    I don't know what I did to it, but it had to come out, so this morning I pulled it and got it into the back of the Subaru for transport to my builder in 1.5 hours. No Lift, no air tools, all grunt and a floor jack... I am surprised how well it fits in the back of the Outback wagon....
    Bob Petitt
    1967 911S Coupe 307653S, my barn find - 55,000 miles Looking for engine #961269 and trans 901/02 #104337
    1971 911T Coupe 9111120264, my first 911 back in my garage
    1972 BMW 2002, my first car - 350,000 miles and counting
    1972 911T Coupe 9112100970, Sporto, parted it out..
    1983 BMW 320i, my everyday car - 138,000 miles and gutless
    2005 Subaru Outback, the daily driver - boring
    2006 Volvo XC90,
    Registry Membership #202
    I wish someone would do a detailed "engine pull for idiots" video. Newbies like me would pay good money for that. You know like: "see that bolt I am pointing to, remove it and don't let it drop into that hole below" instead of "using your plasma coated laser guided tool remove the castelated turbo bushing while, with your third hand, ...". You get the idea.
    101 Projects for you 911 makes it look temptingly easy, but after wrestling with my headlight trim rings for an hour after putting new rubber seals in maybe I should stop while I'm ahead.
    Ulrich
    Mar 2006
    Louisville KY
    If you turn the motor around it looks better in the back of a Subaru.. I have had two 911 motors in the back of our Forrester...
    Tony Proasi
    52 split window coupe
    a new record?
    1.5 hours,now that's fast!
    how many drops have you done before?
    my first (and only) took 3 hours but i wasn't in a hurry.
    ulrich, its easier than you think.
    bob
    bob moglia
    '72 E sunroof coupe
    My first time was 30 years ago...
    I pulled the S90 Engine out of Dad's 356 when he was out of town, took me two days.. This is only around the 10th time I've pulled a 911, It just takes knowing a sequence and getting after it...
    Now for the bad news, pulled the valve covers and found broken Rockers on both #2 intake and exhaust. Pulled the fan shroud and found this.... YUCK... Anybody got a deal on a early 2.0 case and crank??? Maybe time to build a 2.7 and join the RRRRRgrupe..
    Bob Petitt
    2006 Volvo XC90,
    911quest - I agree, but I didn't want to spin it to get it back out
    Quote Originally Posted by 911quest
    But then again, it's a boat anchor now...
    Bob Petitt
    2006 Volvo XC90,
    Quote Originally Posted by Mudi
    It's aluminum. It can be repaired. If it is the original S case, it's worth the $$$.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    That ain't no boat anchor...it IS, however, heartbreaking. Save that case.
    Paul Schooley
    S Reg #863
    R Gruppe #330
    Mar 2006
    Louisville KY
    Fixing the case isn't going to be that bad finding a standard/standard 66mm crank is going to be tough.
    Tony Proasi
    Bob,
    Bummer, hate it when that happens. Good luck, let me know if I can help.
    Phil
  1. 32 Hours 7 Minutes
    By setho in forum Other Car Cultures
    Last Post: 06-05-2013, 09:35 AM
  2. 24 Hours @ Daytona
    By jpnovak in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 01-15-2012, 07:19 PM
  3. Daytona 24 Hours 1/27/07
    By Rico in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 01-19-2007, 11:38 AM
  4. After 12 hours......
    Last Post: 05-27-2006, 01:54 PM
  5. 12 hours of Sebring
    Last Post: 03-17-2006, 03:19 AM
