Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: 7R Fitment
    Senior Member CamBiscuit's Avatar
    May 2006
    Adelaide, Australia
    7R Fitment
    Having a fiddle last weekend and I noticed that the deep sixes just clear the thermostat for the front oil cooler.
    Given the extra width is inboard on the 7R's how do you guys with front coolers get enough clearance.
    I did a search but haven't been able to find an answer
    Looking for engine # 6208151
    '74 RS 3.0 Replica
    '70 911E Bahia Red (SOLD)
    '71 911 S/T Replica 2.3 Twin plug BEAST (SOLD)
    Australian TYP 901 Register #78
    Early S Registry # 1076
    You should go like real 911R or S, oil thermostat in engine bay
    #rennfrog
    Hi,
    Yes they will clear in the rear with the later style thermostat, but you are limited by the tire size, unless you roll the arch. I have 7Rs on my 1971 car and run a later 3.2 oil cooler set up.
    Alan
    here is the therm set up (not fully bolted up yet in this pic)
    Randy Wells
    www.randywells.com/blog
    www.hotrodfilms.com
    Early S Registry #187
    May 2006
    Adelaide, Australia
    Thanks Guys
    The car is currently lowered and running 205/60 15's on deep sixes
    I'd like to retain the 60 series rubber if I can and gain a little extra width
    I think its likely that the ride height might need to come up a little but I guess it's going to be a matter of experimenting with spacers and suspension settings.
    There is a bloke down here that is ex Tuthill who has set up a motor sport workshop. Might be time to pay him a visit I think the current set up is a little to track oriented for my liking....
    '74 RS 3.0 Replica
    I have 944 8X16s on the rear of my MOSTLY stock-flared 911 - they've been massaged a bit but I think my response to your post may still help you.
    My car has a 3.2 Carrera oil tank with a 74-style front cooler setup. With the 8X16s I run a 1/4" spacer in order to clear the Turbo calipers (not needed for body clearance) and made custom lines that go from the oil tank up the body (to about the top of the wheel well), over the arc of the tire, and back down to the thermostat. They're held in place against the body with Adel clamps. I've got so much space that it's ridiculous. I don't remember off the top of my head, but I think I'm running 225X50s.
    We made a similar setup for the racecar we built, and that car's running standard 7X15s. Again, there's so much clearance it's criminal.
    If you were to do this with your 7Rs, you would have plenty of space to work with and not limit yourself so much on tire selection.
    -Marco
    TLG Auto: Website
    Alan, did you end up welding the stud on the body to hold the lines in the rear?
    For clearance, and depending on the car, we sometimes forgo the stud and just use a factory clamp and bolt to hold the rear hard lines...
    -Marco
    TLG Auto: Website
    Quote Originally Posted by OliveR
    Because, you know, that stuff grows on trees.
    -Marco
    TLG Auto: Website
    Hi Marco,
    Like you said I used a factory clamp and bolt, works fine.
    Alan
    Marco,
    Pictures of your setup showing clearance and any fender "massaging" would be helpful....
    Peter
    Early 911S Registry #1224
    911 T/R Inspired Vintage Racer - Retired
    2010 VW Touareg TDI - Torque Monster
    2010 Radical SR3RS - CSR Sports Racer
    Don't Drive Faster than your Guardian Angel can Fly...
  1. Door fitment SWB
    By Bradford in forum Technical Info
    Last Post: 12-06-2013, 07:56 PM
  2. SWB Ext Oil Cooler Fitment
    By 50/50 in forum Technical Info
    Last Post: 03-10-2012, 04:29 PM
  3. H-1 Fitment
    By MY911S in forum Technical Info
    Last Post: 11-29-2011, 01:59 PM
  4. New Minilites Fitment on LWB
    By RTincher in forum Technical Info
    Last Post: 12-18-2005, 04:04 PM
  5. RS Oil Cooler Fitment
    By JuanLopez in forum Technical Info
    Last Post: 02-05-2002, 07:14 PM
