Thread: What color cad plating 1968 911L?
    I have had ben told both silver and gold (Cad 2) for cad plating harware on a 911L. Anybody out there know what color cad plating on SWB 68. Thanks for replies.
    Oct 2005
    Minneapolis, MN
    I've got an original '68 L at the shop.......I'm pretty sure it's gold but I'll check tomorrow.....
    Aaron Hatz
    Flat Six, inc.
    www.flat6.com
    Follow us on Facebook
    www.facebook.com/flatsixinc
    Oct 2005
    Minneapolis, MN
    Well....the engine hardware is gold......was that the question?
    Aaron Hatz
    Flat Six, inc.
    www.flat6.com
    That was the questing. Thanks for checking.
    Magnesium case engines got the gold conversion coating. You can probably use modern zinc with a gold chromate. Probably the studs, too, although I would have to check the shop manual to be sure. The early studs are black oxide.
    Senior Member Grady Clay's Avatar
    Sep 2004
    Unincorporated Arapahoe County, Colorado, USA
    Most (but nowhere near all) of the removable engine hardware was cad chromate conversion plated. During the year (and even in ’69) there was some cad without the conversion (silver color). I don’t think any of the studs were plated but had the black (I don’t immediately recall the process) treatment.
    In general a ’68 mag engine has the plated flat washers and bolts & nuts. Many have a black wavey washer between the plated nut or bolt and the plated flat washer. For instance, the sump plate had un-plated wavey washers and un-plated regular nuts (non-Nylock).
    The ’68 transmission had the same hardware as previous (not plated).
    On the engine and transmission there are very few split lock washers but when used, they were very specific and not cad plated.
    By mid-year ‘68, almost all of the chassis bolts were cad with chromate.
    My ’68 engine & trans have never been apart so one of these days I can do some good documenting.
    Best,
    Grady
  1. Replies: 7
    Last Post: 11-15-2010, 12:08 PM
  2. What color zinc plating on '67S calipers?
    By jimbo in forum Technical Info
    Last Post: 08-26-2009, 11:29 AM
  3. 1968 Carb Linkage Plating Color
    By B D in forum General Info
    Last Post: 05-05-2009, 09:39 AM
  4. Plating Questions 1968
    By B D in forum Technical Info
    Last Post: 02-21-2009, 09:36 AM
  5. Plating color question
    By John Straub in forum Technical Info
    Last Post: 11-13-2008, 08:02 AM
