Results 1 to 10 of 20
Thread: WTB: Strengthened 901 trany with LSD
    I'm looking to build up a beefier 901 tranny (yes, a 901. I like 'em) for my 911. I thought before I go build one I should check if anyone has one I could just buy. What I am looking for is this:
    901 tranny with billet intermediate plate, 904 main shaft, and a limited slip differential. Anyone have on or know of one for sale?
    Thanks!
    Brooke Stabbert
    bstabbert@westwater.com
    (206) 963-9057
    Brooke
    1969 911 ST w/ 2.8SS
    1973 911 RS tribute with 3.3 turbo
    1970 914-6 w/ 2.2S (sold)
    1972 BMW M2 (sold)
    R Gruppe #338
    S Reg # 855
    Hello: I like 901 gearboxes as well. I would try using a early aluminum housing gearbox. That way you won't have to buy the intermediate plate. If you want to use the magnesium housing I would change the intermediate plate and the diff side cover to aluminum ones if you plan on using a limited slip with a big engine. Lastly if you stick with 7" wheels you should be fine. If you want to use 16" wheels with 10" slicks the 901 won't live long. Hope this helps. Thanks, Eric
    With the aluminum intermediate plate and sid cover, the mag cases are pretty much just as strong as the aluminum cases and the mag cases are a lot easier to get axels and LSD's for.
    Of course i would be interested in a built aluminum case 901 as well.
    Brooke
    1972 BMW M2 (sold)
    R Gruppe #338
    S Reg # 855
    Mar 2006
    Louisville KY
    I have several alum. 901 case's if interested in going that route
    Tony Proasi
    52 split window coupe
    911quest - if you have opne already build up as I described, then yes, I am interested.
    Brooke
    1972 BMW M2 (sold)
    R Gruppe #338
    S Reg # 855
    yada yada
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Quote Originally Posted by boxster03
    yada yada
    Is that a comment of disbelief? If so, have you ever driven an early car with a fresh 901. I'm not the only one who prefers the way they shift to a 915, G50, ect...
    Brooke
    1972 BMW M2 (sold)
    R Gruppe #338
    S Reg # 855
    I'll agree a well set up 901 is a great shifting tranny. It's just rare to find one well set up, good luck with your quest.
    Phil
    What gear are you wanting to put on that 904 shaft?
    Tom F.
    '67 911S Slate Gray
    '92 964
    #736
    Howdy Tom,
    Not really sure yet on the gear selection for the new tranny. Still playing around with ideas. I'm thinking something like B, GA, M, S, Y.
    Brooke
    1972 BMW M2 (sold)
    R Gruppe #338
    S Reg # 855
  1. Engine\trany are going back into the car tonight
    By bobmagyar in forum Technical Info
    Last Post: 08-09-2007, 02:28 PM
