Thread: directional swich repair
    The directional switch on my 73 is does not stay engaged for right hand turns all the time...well sometimes it does. The high beam flasher works part time as well. Is the switch telling me it is about to toast itself or is it already too late? Could the engagement issue be spring tension and worn interface on the switch plate? Has anyone repaired one or does anyone know of a repair service out there? There's a guy on the 356 reg site that does 356 switches don't know about 911s. I want to save the original stalk look of the switch, new ones do not look the same. TIA, Steve
    turn signal switch
    Hi Steve,
    I have a similar problem with the t.s lite switch on my 73.5 911T. With the sw in the low beam headlite posn the hi beams come on. In order to keep the hi beams off I have to hold slight backpressure on the t/s handle. I had this same problem in 1989 when I bought the car and solved same with a new exact replacement sw. I kept the old sw and have been playing with it to see if it could be repaired. Im guessing that the problem is not enough spring pressure to hold sw in proper position or mech is lacking enough lube and is hanging up. I will try to clean and lube the sw to see if that solves the problem and any other ideas, suggestions would be appreciated. Performance shows a replacement sw at $200 but dont know if its an exact factory replacement. The no on my switches is 201.077 911 613 301 30 and is a SWF Auto-Electric made in W. Germany sw. TIA
    bob
    Apr 2003
    Portland, OR
    A very common problem. Please read this thread for some ideas:
    http://forums.pelicanparts.com/showt...gnal+quick+fix
    I tried this but the plastic broke and I ended up getting a used one from DC Automotive.
    Harry
    Member #789
    2009 MB C300
    turn signal switch
    Thanks a million, That is exactly what I needed, what a great source,
    Bob
    Senior Member Dezzmo's Avatar
    Nov 2006
    Rhode Island
    Quote Originally Posted by steve shea
    Hi Steve, I'm glad that you mentioned this because the high beam flasher on my 73.5T does not work. I always thought that the early cars did not have this option. I even looked in the original owners manual (page 26) when I first got the car and nothing is mentioned.
    I really like the option of having high beam flashers and had thought about installing a later model turn signal switch with the early straight stalk. So now I'm gonna take a good look at it and see if there's a way that I can get it to work again.
    Oh, and thanks to HarryD for that helpful link!
    Tim G
    Early S Reg #1017
    RGruppe #663
    73 911T 3.2
    00 Ducati 996 Track Rat
    01 Ducati S4 Monster
  1. Directional Tires and the 'Spare'
    By ibmiked in forum Technical Info
    Last Post: 03-04-2015, 12:06 PM
  2. WTS or Trade Koni "S" Struts, '69 Hazard Swich
    By RTincher in forum For Sale: 911 Parts
    Last Post: 01-11-2006, 04:31 AM
  3. Replies: 2
    Last Post: 10-11-2003, 08:59 PM
