Results 1 to 10 of 10
Thread: Steering wheel shaft play. How much is normal?
    I am replacing the standard wheel on my 70T with a Prototipo. After removing the stock wheel I noticed that I can grab the steering wheel shaft with two fingers and move it quite easily, say 1/4" side to side. Is this normal.
    Ulrich
    no should be nice and tight. but a non stock wheel could cause any sorts of problems. always a chance you take when you put on non Porsche parts. remember there is no substitute
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Jul 2005
    Atlanta, GA
    Shaft Spacer
    There is also a shaft spacer that sometimes goes AWOL when the wheel is changed to aftermarket.
    See good description here:
    http://www.early911sregistry.org/for...t=shaft+spacer
    Good Luck
    1973 911E - Viper Green
    1973 911T - Light Ivory, becoming Glacier Blue RS
    Feb 2007
    Thousand Oaks, CA
    Spring and Washer
    Don't forget to move the spring and cupped washer from you factory wheel to the momo. Go ahead and ask me how I know this one
    Tom
    Once the Momo hub is pushed on there is no play, but I was worried about the ease of movement before the new hub went on.
    Ulrich
    Sep 2006
    La Quinta
    If you need to, there is also a bearing that can be replaced on the early cars.
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
    I have the same question, but the link below yields a 404 error. Maybe that is the thread about the spring and the circular retainer clip that go on the stock wheel and are often lost or removed(?) Do those need to be installed onto aftermarket (Momo) wheels also? Is that the 'cupped washer' mentioned below?
    695-347-725-00 356B/C Steering Shaft Bearing Support Ring (bearing race) - $36 @ Stoddard
    914 347 713 00, Support ring only for steering shaft bearing, compression spring, bearing spring - $1.37 @ Stoddard
    In my case I removed the Momo wheel and the momo hub (or is it a spacer, or an adaptor?). When I had the steering wheel on, the car drove, cornered and steered just fine, except... I could notice just the very tiniest amount of 'play (or was it just paranoia I noticed?) when I tried hard to move the steering wheel while driving.
    Also, I have a related question: is there any sort of checks, measurements, or maintenance I should do while I have the hub off?
    Quote Originally Posted by RTincher View Post
    Good Luck
    Apr 2003
    Portland, OR
    This thread at the bird tells the story: http://forums.pelicanparts.com/porsc...-quickfix.html
    Harry
    Member #789
    2009 MB C300
    The early shaft does have a significant clearance between the shaft and the housing, it is quite different to the later shafts and uses a significantly different bearing.
    The early column uses a bearing that (914-347-711-00) is now $290 to replace but which is easily repaired if it has fallen apart.
    The 'quickfix' spacer doesn't work with the early column as the early and late bearings are very different.
    The steering wheel boss should have a 30mm spigot to remove the clearance between the bearing and steering shaft.
    There are a few issues worth inspecting and we are just developing a 'kit' of parts to refurbish the columns on early cars.
    The upper bearing is easy to rebuild and re-use.
    Lower bearings are often poor and could do with replacing.
    I have written some instructions while waiting for all the parts to arrive including a new split tolerance ring made from Ertalyte TX which will remove all play.
    Here is the relevant part of the instruction set.
    Apr 2004
    Chris - Did you ever put the upper bearing "kit" together ?
    Du must schwein haben
    901/05 #305701
    Bultaco Metralla 62 M8
    1968 BMW R69S
    Early911SReg #606
  1. Steering shaft play normal?
    By A_Alfa in forum Technical Info
    Last Post: 10-04-2023, 03:46 PM
  2. Rear wheel bearings - worn but no play?
    By Chris E in forum Technical Info
    Last Post: 05-16-2012, 05:10 PM
  3. SWB Steering Rack, shaft up to the steering column
    By hoffman912 in forum For Sale: 911 Parts
    Last Post: 01-12-2012, 07:11 PM
  4. Ah how nice, no more play in my steering wheel!
    By berettafan in forum Technical Info
    Last Post: 04-02-2009, 09:44 AM
  5. steering shaft play
    By wit61 in forum Technical Info
    Last Post: 04-21-2003, 12:03 PM
