Thread: Nasty discovery during rear bushing replacement
    Looks like I got to it just in time. The springplate covers on my 70T were starting to go in a big way. The hole was made by my screwdriver. Luckily the inside torsion bar tubes and bars were not bad, just a little surface rust. Second pic is finished repair.
    Ulrich
    Dallas, TX
    What really sucks is the price of torsion bar covers today. When I redid my rear suspension 5 years ago, torsion bar covers were like $15 each, now they are about $70. Ouch
    Refreshing the rear bushings really helped the handling of the car.
    Neil
    '73 911S targa
    did you do any preventative cleaning/coating in the tube while you were at it?
    Erik
    Early S # 1107
    All my german equipment is either busted or sold...sigh....in the market for a decent non-sunroof tub!!!!!!! Help me get back to autocrossing!!!
    I got my covers used from DCauto. I think $60 each. Once open I used a wire brush on all of the surface rust on the torsion bar tube and a solid coating of grease on the inner tube and the new bushings.
    Ulrich
    Good catch Ulrich,
    Dec 2004
    Another idea to consider
    When I had my covers off to redo the bushing, I attached a wire brush to a stiff rod and worked it back and forth inside the tube. I then stuck the hose of my vac inside to remove the scale and dirt. I was lucky, the tube was solid throughout. I then attached a sponge to another rod , dipped it in Por15 and swabbed the inside of the tube for insurance. Use caution so you don't get any of the Por15 on the spline connections inside the tube. I used masking tape to mark the length on rod to make sure I didn't get the rod in too far.
    [SIGPIC][/SIGPIC]
    1967 911S Coupe
    1991 944S2 Coupe
    Past projects:
    1967 912 Coupe
    1969 911T Coupe
    1985.5 944 SR Coupe
  1. 1969 911 Steering Column Bushing Replacement
    By Gburner in forum Technical Info
    Last Post: 11-08-2019, 07:16 AM
  2. Front Control arm bushing replacement
    By Merv in forum Technical Info
    Last Post: 03-09-2013, 01:22 PM
  3. Replies: 7
    Last Post: 08-14-2011, 01:35 PM
  4. steering bushing replacement - quick fix on 70T?
    By ulrichd in forum Technical Info
    Last Post: 12-01-2007, 05:40 AM
  5. Front Bushing Replacement
    By HarryD in forum Technical Info
    Last Post: 11-24-2004, 11:34 AM
