Thread: Suspension questions
    Senior Member CamBiscuit's Avatar
    May 2006
    Adelaide, Australia
    OK firstly how do I check my torsion bar sizes? Is there an easy way without pulling the whole shebang apart?
    Also I'm looking at going with Bilstein Struts in my '71. Other than changing ball joints are there any other changes required?
    Thanks Guys
    Looking for engine # 6208151
    '74 RS 3.0 Replica
    '70 911E Bahia Red (SOLD)
    '71 911 S/T Replica 2.3 Twin plug BEAST (SOLD)
    Australian TYP 901 Register #78
    Early S Registry # 1076
    Cam..
    You have to pull it out and measure the diameter in the center of the bar...the only thing the fronts have stamped on the ends are the L and R side marks and a twist direction arrow...this is a good time to check them anyway for rust and corrosion...and put one of the seals back on....it is the grey part that crumbled in your hand as you take them out...
    The Bilstiens will bolt up just fine on your 71'
    Good luck with the project!
    May 2006
    Adelaide, Australia
    Thanks John
    '74 RS 3.0 Replica
  1. Questions for the suspension experts
    By Chris Pomares in forum Technical Info
    Last Post: 07-15-2013, 01:16 PM
  2. Swb suspension questions
    By andrea70 in forum General Info
    Last Post: 04-03-2013, 07:31 AM
  3. Suspension rebuilt questions ...
    By RS-GT in forum Technical Info
    Last Post: 05-24-2008, 12:46 PM
  4. Suspension questions
    By CamBiscuit in forum Technical Info
    Last Post: 05-14-2008, 04:28 AM
  5. suspension & brake questions
    By goofycarp in forum Technical Info
    Last Post: 11-25-2004, 03:56 PM
