Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: What brings RPM limits...
  1. #21
    Jun 2016
    Canada
    Aaah what a read!
    I wonder if things changed over the last 10 years.
  2. #22
    Sep 2017
    New Zealand
    And 5 years further on, what a treasure trove for the enthusiast engine builder! Sad that Grady Clay, Chris Seven and Steve Weiner are all no longer with us. Please PELICAN don't lose this information trove!
  3. #23
    Member kent olsen's Avatar
    Sep 2010
    McMinnville, Ore
    Well I've had my 72T for over 20 years. Since I'm a road racing nut, I started out autoxing, well before I got my Porsche. Then I got into driving at the "track" days. With the help of 'Mike Bruns' in Florida we came up with a 'bullet proof' engine. I had found a 1981 3.0L before I left the west coast for Florida. Mike helped me build this engine, twin plugs and webers and able to turn 8500rpm. However, driving on a race track I found it's torque that pulls you out of the turns, sooo. With the help of another friend with a 72 track car, I contacted Dougherty racing. He had a cam, I think it was a 902-102, that had a lower torque peak, about 4600rpm and 230 ft/lbs and max Hp at 6900rpm. Now when I'd downshift my 915 transmission I'm at 4-4500rpm and it will pull like crazy out of the turn up to the redline, I use, of 7200rpm. I've run this engine for over 10,000 miles and all I have to do it adjust the valves and change the oil once a year.
    Kent Olsen
    McMinnville, OR
    72 911 upgraded 3.0L
    RGRUPPE # 104
  4. #24
    I like these old posts . I do know that the 70.4 RSR crankshafts have a bigger radius on the main journals , not the rod journals .
  5. #25
    Feb 2011
    Northern VA
    Boy, some real heros of these motors posted on this great thread; some no longer with us. Long live the kings!
    That said there are limits to these motors that are not just mechanical. It's a 2 valve overhead cam motor; most will reach reach peak HP below 8k. You might be able to turn them faster and survive with remedies to valve train, crank and oiling; however, horsepower will likely be dropping off. There is a reason why porsche has tried to live within these limits on 2 valve motors.
  1. Chassis No. 300221 brings record $225,000 at RM Auction
    By Unobtanium-inc in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 03-27-2011, 08:14 AM
