Before listing this stuff on ebay I would prefer to sell on a Porsche forum. Due to working 80 hr weeks Please keep in mind that working so many hours will prevent me from instantly responding to questions you may have. I have 6 years and over 3000(opps 4000) posts on the Pelican board without any bad transactions. If you want something im selling it will only be held if secured payment is recieved
I have over 3000 sq ft of collectable 911 parts in my collection. I do not do this for business. Im just an insane Porsche fanatic that is out of storage space. I am located on Long Island. If you need something not listed I most likely have 5 of them. Feel free to ask
Here we go
Complete ready to run 1973 Carrera R/S 2.7 MFI System(019 pump). All parts including air filter to frame mounted pump. System was last run 2 years ago and is ready to use as recieved. Sprayed down with wd40 and stored indoors completely sealed since removal $6000.00 I will include the correct distributor for an additional $450.
Complete ready to run 1972 911E 2.4 MFI system including everything(like the R/S system). Last run 4 years ago and worked perfectly. Stored indoors and sealed after wd40 treatment. $3500.00
New never installed fresh from the boxes set of 40mm Webers with new OEM linkage and new 36mm REP manifolds from PMO. $2900
Bosch 0-231-169-010 Euro R/S distributor excellent condition $450
Bosch 0-231-169-010 911S distributor excellent condition $450
3.0 engine case checked and ready to use $650.00 Note the case has some cosmetic web damage that will not affect anything. The case was used for 10k miles after the damage.
3.2 case in excellent visual condition. Not checked by machinist but looks great to the eye. $725.00
2.7 7R case unmodified(no case savers) and greasy. Was removed and disassembled for the first time 6 years ago to use the crank. Case is in great shape and perfect for use as is or to add the case savers for a hp build. $425.00
3.0 crankshaft Std, Std in great shape. Wont need a polish to use but thats up to your preference. $950.00
2.7 Crankshaft Std, Std in great shape. Wont need a polish to use but again thats up to your preference. $550 SOLD
3.0 CIS system for 81-83 usa type with steel lines. 100% complete. Ready to bolt on and use(no issues). Includes air filter. $475.00 sold and shipped
Stainless Steel oil tank from 1985 Carrera. Correct fit for all 74-89 911 cars. This is the best choice for baffeling, rust resistance,and capacity. Tank is clean and complete with sender. $450 sold and shipped
NOS new vintage Scheel racing bucket (1) still in plastic sheath in perfect cond color black (pics avail) Purchased in Germany and shipped home back in the mid 70's $1400.00SOLD
Bilstein 930 front struts with sport inserts and upper bushing assemblies(see muffler pic below) from a 1980 930 with 21k miles. The car was not wrecked. Housings are perfect and the sport inserts are excellent. $750.00 If desired I have the Bilstein rears available(from same car) for an extra $50.00 (only if buying the fronts) Note rears are not available separetely. Total for all 4 is $800.00
NOS set of 16x8 and 16x7 Fuchs wheels with new mounted and balanced Michelin tires. Not a blemish of any kind wheels were installed on a car once but never driven. Will not seperate the set of 4. $1800.00 SOLD
New M&K 2 in, 2 out stainless muffler with 2" outlet tips $325.00 SOLD
NOS set of 40mm Weber carbs complete with New linkage and manifolds. $2900.00 SOLD
NOS new 3.0 Mahle nikisil cylinder set with excellent set of low usage Cosworth 10.4(?)to 1 pistons and wrist pins. $1600.00
Mahle factory oem R/S pistons and cylinders set of 6 in excellent condition $975.00
2.0 S crankshaft STD STD ready to use $675.00 SOLD
Fresh fully rebuilt 2.7 cylinder heads set of 6. All new guides, valves,springs,and retainers $1200.00
2.7 R/S cylinder head set of 6 . Excellent used condition. Yes they have factory MFI ports. Valves just cleaned and lapped. $1500.00
2.8/2.6 Sand cast alum case with brand new 92mm hi dome arias pistons and mahle cylinders(also new). Case is freshly line bored and spikot bored to fit the 92mm cylinders. $4200 Note: I have everything to complete this engine and its all new or freshly machined.
New in box S cams from Web cams (non mfi) $475.00
Set of 6 matched and fresh rebuilt 3.0 rods $425.00
Set of 6 fresh rebuilt 80-83 usa spec 3.0 cylinder heads, New valves, guides, springs and retainers. $1200.00
1967 911s double pocket door panel set (rare) in perfect condition. Black $650.00 SOLD
1967 911s rear decklid (red) with beautiful grill, 911s emblem, lights and hinges. all in perfect condition $700.00 SOLD
1969-73 911 Targa carpet set black with grey hairs new in box $275.00 SOLD
Factory H1 headlight set in excellent condition $925.00
NOS NLA oem 930 Rear flares. In factory primer with oem stickers in place. These are the type that have the full size smaller (post g50) torsion bar holes.
Most sought after for RSR conversions. $875 for the pair.
914/6 rear control arm set with correct 5 bolt hub assembly. From a real 1970 914/6. $975.00
914/6 Fresh rebuilt tranny. Not used since overhaul. This is a correct box from the 70-72 cars, not a converted one. Can provide case id # for interested buyer. $2400.00
914/6 axle set. Excellent used condition. $475.00
Almost new complete set of B&B exhaust and muffler. Used for less than 400 miles and looks brand new. This is the type with 1 3/4" header pipes w/heater boxes. Comes with mounting clamps and optional outlet tips. Was ordered and used on a 1982 SC. I think its a correct fit for the 3.2 cars as well. Cost me $2800 2 years ago. $1800.00
Set of 4 15x4.5" 1967 S fuchs wheels. Original unrestored condition matching set. $4000.00
Set of 2 15x7 date code of 12/72 1973 original Carrera R/S fuchs 3 prong type. $1600.00 sold and shipped
Set of 2 15x8 Both have date code 12/73 rare early 3 prong type fuchs $1900.00 SOLD
930 euro 4 speed transmission type 930/36 (came in 86-88 euro 930 cars) with less than 25k miles. Yes it does have LSD. It has been sitting properly stored for quite a few years(10-12 years). Still has its oil inside and is NOT at all oxidized. Comes with clutch fork. Im sure its just as good now as it was when pulled. $3500.00
Many 915 transmissions (at least a dozen) 7/31 and 8/31 units. $900-$1700
At least 100 Fuchs wheels available.
I will add to/edit to this list shortly. Like stated above I have over 3000 sq ft of items including some very rare stuff as well as more common items. My parts collection consists mostly of 65-73 parts.
Kurt Williams
Contact info is
kurt @ digitalprovisions.com
