Thread: Can Neatrix bushings be lathed to fit a SWB with Sway-Away adj spring plates?
    Seeking advice from the experts. TIA!
    _B
    Sent from a pay phone
    888888 eL, Oph'eL'ia
    Instagram: werk_crew
    www.werkcrew.com
    www.werkcrew.tumblr.com
    www.handofwinter.tumblr.com
    Turning bushings
    Bob, we made a wood buck to the correct bushing i.d. then froze the bushing on it and lathed the out side to the desired dimension.
    The cold part warmed in a few seconds when mounted to the metal lathe and the cutting bit, so that was of marginal benefit. Turning speed went from slow to a medium fast and would chatter/cut up the material if at the wrong speeds. Found a good cutting speed, and cut four bushing in about an hour. It was removing minimal material or it would grab/chunk.
    This is the wood buck with an old bushing on it (so I can remember why it is being saved).
    When removing material from the inside of a bushing the buck has a snug fit pocket to insert the bushing.
    Hope this helps.
    Bob
    Early S Reg #370
    Interesting. I wonder if a constant spray with friendly refrigerant on the bushing would increase rigidity and reduce the chattering and grabbing during the cut?
    Sherwood
    Clever! Thanks for the the reply and pic!
    _B
    www.werkcrew.com
  1. WTB: Adjustable spring plates Weltmeister / Sway-a-way for a SWB
    By Mdezeeuw in forum For Sale: 911 Parts
    Last Post: 03-01-2013, 02:29 PM
  2. Replies: 1
    Last Post: 09-25-2011, 08:11 PM
  3. Sway a Way Spring plates for SWB 911
    By Carrerax in forum For Sale: 911 Parts
    Last Post: 08-13-2009, 04:56 PM
  4. FS: Sway Away Adj Spring Plates 65-68
    Last Post: 09-27-2008, 08:28 AM
  5. Neatrix spring plate bushings glue?
    By Wolf Knierim in forum Technical Info
    Last Post: 01-13-2004, 11:13 PM
