Thread: MFI Airbox hose connection
    Was doing some oil/grime cleanup work post-A/C delete and when I removed the air cleaner housing I noticed there was a hose just laying there disconnected. It looks just like the hose that was connected to the housing (lower one in pic). Anyone know where the top one is supposed to go?
    Thanks for the help!
    911S Registry #837
    1972 911T Sepia
    Those look like the hoses for the fuel tank ventilation system. One goes on the nipple on the fan shroud behind the fan, and I THINK the other one goes on half of the crankcase vent fitting on the air cleaner-- but NOT the nipple for the oil drain, that goes to the oil drain hose to the oil reservoir on the side of the engine.
    Interesting, I wonder if they're both equal in function (both must come off the charcoal canister). I'll look for the shroud connection, thanks.
    911S Registry #837
    1972 911T Sepia
  1. what is this hose on the airbox?
    By tgittens in forum Technical Info
    Last Post: 02-07-2010, 08:23 AM
  2. FS: 65-68 airbox; 69-73 airbox base
    Last Post: 07-06-2008, 07:57 AM
  3. Heater connection for MFI from heat exchanger
    By kenikh in forum Technical Info
    Last Post: 09-29-2005, 12:52 PM
  4. Sucking Oil up the Vapor Hose - flooding airbox
    By yopurp in forum Technical Info
    Last Post: 03-07-2004, 07:43 AM
