2 questions on this topic:
70/71 sport seats- only leatherette? only perforated?
If so, when did leather become available as an option? 72/73? And is 72 when the style of the seat changed? (ignoring the base/locking mechanism changes)
1974 MFI Carrera
1992 Carrera RS
S Reg #1245
Leather option goes way back before 911 times. Leather is always perforated on the seating surface, vinyl is not.
Also, perforated for vinyl would be on the bolsters, I have an original set in storage, I'll double check.
Regarding the sport seats changing....well, they really didn't change at all from 69 to 73, so I'm not sure what you're asking. The only change was in the bases with the seat belt interlock in 72, and the double locker for the sliders in very early 73.
Eric
Eric have you ever heard/ read why that is? What I have understood is it not a good thing that the bolsters are perforated since the moisture eats the foam (appears now that we are 20-30 years later). Perforated center panels make sense because of your body warmth.Also, perforated for vinyl would be on the bolsters,
Richard
am I wrong or:
72/73 (leather) sport seat bolsters are not perforated.
69-71 (leather) sport seat bolsters are perforated.
Registry member No.773
I have original sport seats in a '71 and '73, both vinyl. The '71 has perforated bolsters and basketweave seating, the '73 has no perforations at all.
1973 911E - Viper Green
1973 911T - Light Ivory, becoming Glacier Blue RS
the head rests did change post 71MY (peanut vs D shape). Also concur that bolsters were perforated 71MY and earlier -- thus non perforated on 72MY and later MY seats.
Early 911S Registry #750
1970 911E - The Good Stuff
2001 Toyota Landcruiser
This is the jist of what I was asking- perforated bolsters vs. non (sorry, should have been more clear)...I guess regardless of year, they can come in leather and vinyl...it was a bit confusing for me b/c I see alot of seats being redone in both and I wasn't sure what the "correct" material was...Originally Posted by 911T1971
Thanks for the info guys
1974 MFI Carrera
1992 Carrera RS
S Reg #1245
When Tony redid these for me, he said that if sport seats came with plaid or houndstooth or other cloth for centers, then there were no perforations on the bolsters. If normal basketweave material, then the bolsters had perforations. Seems reasonable enough, holes with plaid centers would look a little busy.....
John Gray
70 old air
86 middle air
95 new air
