Results 1 to 9 of 9
Thread: Special Parts!
    Special Parts!
    As the new RSR engine build gets under way, we are having to re-manufacture a few of the rare unobtainable bits that will help make the motor as close as possible to the real thing.
    Neil Bainbridge, here in the UK, has made these for it, oil fed camshafts. Starting with EN24 steel billets, they are ground, heat treated and hardened to RSR sprint profile. They have been rifle drilled hollow up through through their length, then the small oil spray holes drilled in each ramp face. New oil feed bolts are being made which hold the cam gears and feed the cams.
    The cam gears Neil made are 'vernier' type, so instead of the pin in the hole standard version, with these you have total control over the cam timing, to get it absolutely spot on!
    Next step is to make the oil fed chain box covers, was thinking about CNC'ing from the original pair we have on loan, but maybe sand casting is the way forward, anybody know somebody who can do that?
    cheers, Mike
    Member#1664
    1972 911 S/RSR to Martini Prototype specification
    http://www.ddk-online.com/phpBB2/viewtopic.php?t=15294
    Sexy stuff! Hope you find the manufacturer you need!!
    Peter Kane
    '72 911S Targa
    Senior Member Macroni's Avatar
    Nov 2006
    Philadelphia PA
    [QUOTE=Mike_Moore]
    Check with the technical representatives [+41 71 955 38 00] at Buhler Die Casting in Uzwil Switzerland. They manufacture the casting equipment and should be able to point you to a local shop.
    86 Sport Purpose Carrera "O4"
    Mike,
    Sent you a pm.
    Harold
    #334
    now these are really special!
    Solid rockers, made using Formula One technology. These have been designed with the exact pad and foot geometry of the original R/RSR rockers.
    They have a Diamond-Like Carbon (DLC) coating which gives high levels of hardness, low friction and resistance to wear.
    You can see the spiral oil groves on the inside which you need for running with nitrided camshafts.
    cheers, Mike
    Member#1664
    while the work progresses on the engine build, Neil Bainbridge has had a batch of 2.8 RSR oil coolers re-manufactured along with the larger 3.0 litre one. The build quality is fantastic, they really are beautiful!
    cheers, Mike
    Member#1664
    Prices
    Why is everyone so secret about prices? I will take one of each depending on the cost. WHAT ARE THE PRICES? Even approx prices?
    Quote Originally Posted by gunzel
    Not really posting here as adverts to sell this kind of stuff, more just to show fellow enthusiasts what we are doing for our engine build. Would have put it in For Sale section if that was the idea!
    cheers, Mike
    Member#1664
    Quote Originally Posted by Mike_Moore
    YUM! Who makes them and how much for a set?
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  1. A special 72S
    By vipergruen in forum General Info
    Last Post: 03-25-2021, 04:32 AM
  2. This one will be very special
    By John Z Goriup in forum Technical Info
    Last Post: 11-18-2018, 11:53 AM
  3. Something special...
    By ajwans in forum For Sale: 911 Parts
    Last Post: 02-19-2009, 09:04 PM
  4. Open House at Pelican Parts with Special Guest Brian Redman
    By W Scott Shores in forum General Info
    Last Post: 03-24-2006, 04:44 PM
