Results 1 to 8 of 8
Thread: FS - NOS 18mm Early Rear Sway Bar Set-Up
    May 2006
    CT
    This is a NOS early rear sway kit that uses a later model 18mm rear bar.
    It consists of the following:
    1. later model OEM 18mm bar (911-333-701-07)
    2. early sway bar chassis mount brackets (901-501-180-20)
    3. early sway bar drop links (901-333-731-01 and 901-333-732-01)
    4. ball pins for the trailing arms (901-331-571-02)
    5. All bushings
    6. sway bar mount brackets (901-333-753-01)
    All NOS parts
    $250 plus shipping
    http://forums.pelicanparts.com/showt...81#post3753981
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Will that work on a 70/71 car with steel arms?
    Sep 2007
    Norway
    Hi
    If you have a buyer on the sway bar itself, I could be interested in buying the rest hard ware. I guess shipping price to Norway for the long bar would be too expensive??
    Jul 2006
    Corvallis, OR
    What would you run on the front to match up with that rear bar? To fit a early car 69-73?
    May 2006
    CT
    sway bar
    the original plan for the project was to use a 15mm thru body bar on a '69E.
    Tom Butler
    1973 RSR Clone
    1970 911E
    Goldmember ttweed's Avatar
    La Jolla, CA
    Quote Originally Posted by RPMClassic
    It is a later "Type 2" bar, for the '78-89 SC/Carrera, but it will work on an early car with a simple bushing fabrication to extend the arm for the droplink connection. See this article by my mechanic. The only early "Type 1" 18mm bar available was used on the '74-77 911S, although there was an 18mm used on the '76-77 930, but it had a bend in the middle of it to clear the 930 transaxle.
    The front early 930 18mm "through the body" bar is a good match for this one in the rear, but is even harder to find, due to the smaller numbers made.
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
    David Sperow Davz912/911's Avatar
    Sep 2006
    South San Francisco
    You've got mail....
    911S registry #1103
    R-Gruppe #513
    1967 912 converted to 2.2
    Period Dune Buggy
    Some drive Porsches' to be seen.....
    I prefer it when nobodys looking.
    May 2006
    CT
    SOLD pending payment
    Tom Butler
    1973 RSR Clone
    1970 911E
  1. FS: Factory 18mm rear sway bar
    Last Post: 02-28-2014, 10:58 AM
  2. WTB: Factory 18mm rear sway bar
    By porschestrabe in forum For Sale: 911 Parts
    Last Post: 11-03-2013, 10:57 AM
  3. WTB: Factory 18mm rear sway bar
    By EA911 in forum For Sale: 911 Parts
    Last Post: 11-10-2009, 08:16 PM
