Results 1 to 10 of 12
Thread: Strong Gas Smell
    Strong Gas Smell
    I have developed a strong gas smell coming from the car. I do not see any type of leak either in the engine compartment from a gas line or anything in the trunk/ however the smell does seem to come from the front of the car. Any suggestions for trouble shoot? No leaks that I can find so it must be fumes. Best way to track down fume leak? Much stronger in the cold weather. Thanks
    Yes the Gas lines are pretty much original 1970 stuff if that helps....
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Mar 2006
    Louisville KY
    I would pull the front suspension cover and take a look at the fuel lines if the leak is small enough it can pool on the cover then evaporate.
    Tony Proasi
    52 split window coupe
    It usually is the hard lines in the center tunnel. But I've had 2 cars that had signs of a leak in the seam of the tank only visible after the tank was out. I had a 73 that the black vent box that is behind the temp gauge come loose and a wicked gas smell persisted in the trunk till I chased it down. Once hooked up fumes went away. Hope this helps.
    Rick
    67 Normale, Old Rusty
    67 R Inspired and on a Diet
    73 T/ST Caged Beast
    RGruppe #383
    S Registry #739
    Jun 2003
    Bend, Oregon
    There's an easy thing to check that frequently is the cause of your problem. Check the "black box" that is mounted in the trunk on the driver side of the car. Remove it and pressure test with water or air -- sometimes they leak just enough to cause a smell, but it's not visible. If it does leak, you can repair it with glue.
    Cheers,
    JohnA
    Quote Originally Posted by jaudette3
    Cheers,
    JohnA
    +1
    Michael does it feel like you are sitting right on top of an open can of gas while sitting in the drivers seat? If so, as John pointed out it could be
    the "black Box" located near the drivers side hood strut that is cracked, or as was the case with my car, a breather hose that had come loose to the box.
    1973 911E Viper Green
    2021 Spyder PTS Signal Yellow
    2019 Carrera T Racing Yellow
    2008 Boxster S Ltd. Ed Orange
    2007 911 GT3 Meteor Grey
    @Type911 instagram
    RGruppe #295
    Zuffenhausen secret weapon
    thanks for the info guys. After some investigation it appears that the leak is coming from the front around the fuel pump. I did not remove the bottom protecto plate but can tell it has been dripping from that area where the fuel pump is mounted. Next thing is to take it to my local wrench to get it up on the lift and pull the plate and find out whats leaking. When it comes to gas leaks I am going to leave it to a more skilled bunch.
    I know I'm a little late to this thread, but here's my $.02:
    I used to have a similar situation, especially after filling up. It turned out to be the big rubber connector hose that goes between the filler neck and the tank. It did not leak, but was just dry rotted enough to leak fumes. Once I replaced it the car has been fuel-smell free and no more headaches while driving.
    Tom Morgan
    Charlotte, NC
    '18 Carrera T - R #368, S #692
    1973 Giulia Super 1.3
    Senior Member rgrimm's Avatar
    Jan 2006
    Fargo, ND
    Don't know the exact layout of a '70, but I had a pretty strong gas smell after filling all the way up. Turned out to be the gasket around the gauge sender on the top of the tank...
    Roger
    68 Sand Beige 911 Coupe #11830091
    84 Moss Green 911 Carrera
    Feb 2007
    Thousand Oaks, CA
    Hey Boxster03,
    Changing your fuel line is a piece of cake and definately a DIY. Paul at Stoddards has the fuel line and Wurth USA can provide the Nora clamps.
    Here's a good thread on the subject including some great input from our recently lost guru Warren Hall aka. Early S Man.
    http://forums.pelicanparts.com/showt...ferrerid=16769
    Took me about 2 hours on my 69E which included removing the pump and lots of cleaning. I have yet to complete the engine-side lines, but that should be pretty straight forward too.
    Hope this helps.
    Tom
    Thanks again for all the info. It actually was the fuel pump o ring that was leaking. a non "sanctioned" repair was made to replace it. we will see if it holds. If not I will replace. I will also monitor the fume smell as that could be a different problem.
  1. Strong Euro = upward price pressure?
    By MountainRoads in forum General Info
    Last Post: 03-26-2011, 08:51 PM
  2. Are 911S Cars Still in Strong Demand?
    By wgwollet in forum General Info
    Last Post: 12-21-2010, 02:37 PM
  3. You smell that?
    By Homemade 911 in forum Off Topic
    Last Post: 04-15-2009, 01:20 PM
  4. 911s are strong, but this is WRONG!
    By Jens in forum General Info
    Last Post: 02-20-2005, 03:36 AM
