Results 1 to 8 of 8
Thread: 380 mm 914-6 / "RS" steering wheel with extended hub FS
    This is the steering wheel that I recovered for my car last year. This is an original 914-6 wheel with the part # 914.347.804.10. Date code is 1/70
    Unlike most recover jobs, this wheel has the correct fine grain leather. Most restoration shops use a heavy grain leather that looks cheap. Also, you will notice that the spokes have been finished properly. Even the $350.00 recover jobs usually have the edges cut off raw instead of being skived and neatly folded over like the factory did.
    Included on this wheel is an aluminum hub spacer that is an diminsional replica of the original, only made from aluminum instead of plastic. It is all held together with allen head hardware. This moves the wheel back approx 1 1/4" so that your knuckles dont hit the dash.
    I will also include the aluminum insert that snaps in the face of the hub to back up the horn button cup
    The only notable flaw in the wheel is at the very bottom where the two seams meet. There is a small gap and the bottom seam doesnt exactly line up from front to back. Once installed on the car, you would need to essentially stick your head into the center of the wheel to see this, but I want to point it out.
    This wheel looks great and feels better than any 380mm factory wheel you have ever installed in a 911!
    $650.00
    1974 911"S" - Silver
    10 sec 67 VW
    Early "S" Registry #439
    Offers???
    10 sec 67 VW
    PM sent.
    Michael
    Michael Moenstermann
    Osnabrueck - Germany
    Early 911S member #1052
    'While accelerating the tears of emotion have to flow off horizontally to the ears.'
    'Understeer is when you see the tree you are hitting, if you only hear the tree then it was oversteer'.
    'You can't treat a car like a human being - a car needs love'. (all Walter Röhrl)
    Pending ...
    10 sec 67 VW
    Interested if the sale falls through.
    Brooke
    1969 911 ST w/ 2.8SS
    1973 911 RS tribute with 3.3 turbo
    1970 914-6 w/ 2.2S (sold)
    1972 BMW M2 (sold)
    R Gruppe #338
    S Reg # 855
    Sold - Thanks Michael
    10 sec 67 VW
    in the market for a 997
    May 2007
    Anybody know where a guy may find a spacer like that for a 380mm wheel?
    Scope Creep Poster Child
    May 2003
    Eugene, Oregon
    I made my own. PM if you like.
    -Scott
    Early S Registry 1047
    ’15 VW GTI
    '70 911E, Sold
    '56 Cliff May Prefab
  1. FS: Special Extended Hub 380mm "RS" "RSR" Thick Grip Steering Wheel
    By Allen Henderson in forum For Sale: 911 Parts
    Last Post: 06-06-2014, 12:47 PM
  2. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 03-17-2012, 07:56 AM
  3. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 03-09-2012, 07:53 PM
  4. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 03-03-2012, 08:51 AM
  5. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 01-24-2012, 01:59 PM
