Thread: Correct clamps for oil filler pipe on 71
    What kind of hose clamps are correct for the filler pipe on a 71? The parts catalogue lists "44-64/9 verz.." The "44-64" probably means 44 mm to 64 mm, since the outside diameter of the hose is 55 mm, but what does "9 verz." mean? Would someone, please, post a picture of the original installation? I've got big, ugly radiator hose style clamps on there, now. Thanks in advance. Tom
    Tom F.
    Long Beach, CA
    verz. stands for Verzinkt, which means "zinc-plated."
    correct clamps for oil filler pipe on 71
    Tom, if you'd like I can send you some pictures of the clamps on my 71. I may even have some to give you, that style can only be found used. Contact me at cdih@charter.net
  1. Fuel Filler Pipe
    By mshaver51 in forum Technical Info
    Last Post: 03-14-2015, 03:09 PM
  2. correct diameter for ST or RSR twin outlet pipe
    By JBQuick in forum Technical Info
    Last Post: 05-28-2007, 10:06 AM
  3. Blau Fuel Filler and Oil Filler Caps
    Last Post: 12-15-2006, 04:21 PM
