Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: car pulling left, faulty lsd?
    hi, my car is pulling left underacceleration, not real bad, but still not as it should be. So far we've done an alignment, four-corner balancing, wheel bearings, overhauled the brakes, checked and adjusted all torsion and sway bars, still no luck. All I can think of now, is it must be the LSD differential (915 box), that distributes the power unevenly. Step on the gas; it pulls left. Press the clutch; it goes straight. Do any of you guys have any other ideas or experience with this? Thanks for your input!
    Arjen
    early s registry #661
    r-gruppe # 604
    With a reg. ZF LSD I (think) it would pull to the left both under and off load.
    Is yours a quaife than?
    Richard
    Mar 2006
    Louisville KY
    How are the shocks?? You should be able to fine tune the pull out with somemore alignment work. Has the front pan ever been replaced?
    Tony Proasi
    52 split window coupe
    richard, I have never had the gearbox open, so I am not sure which type LSD is inside.
    tony, the shocks are good and the alignment was done very seriously. All suspension work was done by Duel Motorsport, a very reputable Porsche shop here in Holland.
    The fact that it only pulls under load, and goes straight as an arrow without load or under braking, makes me think something is wrong in the driveline.
    I will be replacing the engine, hopefully in a month or so, and I guess I'll have to take a closer look at the diff at that time.
    thanks for the input,
    Arjen
    r-gruppe # 604
    The Netherlands
    left pull
    Why would a ZF LSD pull to the left or right under load? Seems odd to me. Never heard nor felt that before with my LSD.
    Cees
    Dec 2002
    Birmingham, MI
    I'm interested to hear more on this. I sometimes notice the same sensation, although subtle, in my 73S with factory LSD.
    Jared
    '73 911S #0793
    '69 912_ #0602
    Early S #0454
    RGruppe #0391
    Arjen,
    LSD issues can certainly cause the symptoms you describe.
    You can remove it through the side cover, unbolt the ring gear, and disassemble it to inspect all the plates and baskets. Carefully observe the thickness and the order that the plates are stacked in.
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
    This symptom happened to me once on my way to Barber Motorsports park, the car started to pull right under acceleration. One of my rear tires was losing air.
    Have you checked the tire pressures?
    Gregg
    Ditto.
    Tire pressure check. I've felt it in a '94 Speedster. Accelerate and it went one way. Come off the throttle and it came back. Rear tire low.
    Tom
    Early S Registry #235
    rgruppe #111
    Tire pressures are 26 psi cold on all tires (BF Goodrich Comp T/A 225/50ZR15 and 245/50ZR15 on 7&8x15 Fuchs), so nothing weird there I think.
    With the rear wheels lifted and turning free, if I spin one rear wheel, the other will turn in the same direction. However, if I spin one rear wheel, my son can easily hold the other still. Is that a clue? Sorry for being ignorant in this....
    r-gruppe # 604
  1. Pulling a '71T Transmission
    By Stretch32 in forum Technical Info
    Last Post: 09-15-2013, 08:05 AM
  2. Door Pin Pulling Tool in SF bay Area?
    By kentf14 in forum Technical Info
    Last Post: 10-14-2010, 08:07 AM
  3. Tool for pulling door hinge bolts
    By 67Porsche911S in forum Technical Info
    Last Post: 11-19-2009, 01:39 PM
  4. Pulling up old Threads - Pictures gone?
    By gruen911 in forum General Info
    Last Post: 07-12-2006, 09:31 AM
  5. Faulty tail lights
    By PNW 73S in forum Technical Info
    Last Post: 08-09-2002, 01:50 PM
