Thread: Correct Finish /Fan Housing 67S
    Senior Member Varooom's Avatar
    Oct 2006
    SoCal
    I just cleaned and blasted my fan housing and want to make it spot on correct for my car. I know most do a powdercoat finish but I do not want to duplicate the already nice aluminum finish. I am not a fan(no pun intended) of that 'glossy' colored finish that I see.
    What is the correct factory finish? Zinc,Cad,clear over raw aluminum??
    -I like the finish (pics)on this real nice S rebuild someone sent me. Anyone here do this build? Thanks.
    Steve Var.
    _____________
    67S
    66 912
    Senior Member Neunelfer's Avatar
    Dec 2002
    Sandy, Utah
    What you're looking at in that picture is a sand cast aluminum case etc. You can see the difference in contrast to the magnesium fan.
    I'm not certain that "any" sealant was used on the magnesium. Definately not zinc or cad plating. One thing I noticed in the picture is the strap. I "believe" that should be yelow cad. It could very well be the early straps were painted but most I've seen are yellow cad (best to source yellow zinc now)
    Walnut media is the best I've seen on magnesium.
    Hope that helps.
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    80 VW “Caddy” Pickup
    72 R75/5 Toaster Tank
    PMB Performance
    Love Us On Facebook
    The early one's are indeed painted black.
    Richard
  1. Turn signal housing- what exterior finish is correct?
    By mobius911 in forum Technical Info
    Last Post: 04-13-2012, 02:28 AM
  2. FS: Small Fan and Housing....Special RSR Finish.
    By Mike_Moore in forum For Sale: 911 Parts
    Last Post: 10-25-2011, 02:51 AM
  3. How do I get the correct finish on my 71' gas tank??
    By erick72pors in forum Technical Info
    Last Post: 11-29-2006, 12:08 PM
  4. Correct Magnesium Finish?
    By Chris G in forum Technical Info
    Last Post: 05-18-2005, 02:36 PM
  5. Correct Finish for '73 P O R S C H E script
    Last Post: 01-11-2005, 05:36 AM
