Thread: 'Franken-box'
    Member #1525 gilbert911's Avatar
    Oct 2006
    Europe
    'Franken-box'
    I'm looking to transfer the (short) gears from a '66 901 box
    into a '70 901/911 housing
    A straightforward operation?
    Senior Member CamBiscuit's Avatar
    May 2006
    Adelaide, Australia
    Hi Gilbert
    I have done this in my '71 911 'box. Well my mechanic did I went with AFMSX and am very happy with the results! I would have had a crack at it but no time and no place to work on the car at the time....
    Makes the car feel like it has gained a few horses!
    Cheers, Cam
    Looking for engine # 6208151
    '74 RS 3.0 Replica
    '70 911E Bahia Red (SOLD)
    '71 911 S/T Replica 2.3 Twin plug BEAST (SOLD)
    Australian TYP 901 Register #78
    Early S Registry # 1076
    Oct 2006
    Europe
    Hi Cam,
    Yes, same as me AMFSX.
    I'll be getting on with it then....
    Cheers
    Scope Creep Poster Child
    May 2003
    Eugene, Oregon
    If I remember correctly, there are one or two components that are narrower in the earlier gearbox. The factory manual is quite clear about this. I think it might be first and/or second gear? In any event, you need to make sure that you use compatible components.
    I converted my 911 box to AFMSX, but I used a 914 input shaft/second gear, so the specs were the same as my 911 components. I like the gearing so far, but I only have 12 miles on it, and have yet to use 5th!
    Early S Registry 1047
    ’15 VW GTI
    '70 911E, Sold
    '56 Cliff May Prefab
