1997 Porsche 993 Twin Turbo
VIN # WP0AC2991VS375979
45,500 Miles
Glacier White on Dark Gray Leather
6-speed Warranty
2-Owner California Car Carfax Certified
Clean and Clear Title
Offered at $69,990
Don’t get fooled by low mileage cars or cars that “don’t need anything.” I’ve dealt with these cars enough to know that they ALL require serious maintenance. And, the best person in the business who knows these cars is Tony Callas of Callas Rennsport.
Tony has done more development work on these turbo cars to help fix many of their inherit factory problems. And, this car is no exception. Within the last couple hundred miles, Callas did the following expensive repairs (over $27,000!):
Complete valve job
Major engine rebuild (23k mile/24 month warranty): new piston rings, rebuilt heads, resurfaced cams and cam towers
Rebuilt tach and boost gauge
New chain rails
New engine sound pad
New chain tensioners
Upgraded turbo cut-off valves
New HD RS Clutch, ring gear, pilot bearing
New lightweight flywheel Callas turbo oil line repair (return lines from turbos to center pump…very common problem on 993 Turbos)
Furthermore, the following repairs and enhancements were made:
Bilstein PSS9 Coilover suspension system
Rebuilt rear shocks
Dansk sport mufflers
K&N air filter
New Tires
9’s and 11’s BBS LM 18” wheels
4-wheel alignment/corner balance
Finally, the car just had a major service which included: transmission service (front and rear differentials), new drive belts, oil cooler fan resistor, drive belt sensor, spark plugs, fuel filter, updated boost hoses, dist. Cap, dme relay, and a/c parts.
There is nothing else that this car needs. Plus, with the recent pre-purchase inspection and repairs from Tony Callas, you can’t buy a better-maintained car.
This car has no surprises and no stories!
This car came with some great factory options:
X54 Oval Chrome Exhaust Pipes
X70 Metal Door Sill w/Insignia
X71 Aluminum Instrument Dials
373 Left Side Sport Seat with height adjuster
374 Rigth Side Sport Seat with height adjuster
454 Automatic Speed Control
520 Alarm
650 Sunroof
692 Remote CD Changer
All books and recent records are included.
If you have any questions, please do not hesitate to contact Paul at 714-668-0345 or paul@autokennel.com
For tons of pictures, either cut and paste the following URL into your browser, or click here: http://www.AutoKennel.com
