Thread: Grumbling Noise
    Grumbling Noise
    so I just started getting this sort of low "grumbling/dragging" noise from the back when coming to a stop. If I hit the brakes hard and do a quick stop I don't get the noise its really only at the slow down braking when I am almost coming to the stop. Any ideas
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    E-brake cable is binding/seizing up?
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Maybe a sticky caliper or piston?
    If 1 piston sticks more than another, the brake pad might will apply uneven pressure and be slightly crooked.
    Mar 2006
    Louisville KY
    Quote Originally Posted by Flieger
    I agree probably cailper or hose problem if you take the wheel off and check the pads one is probably worn more then the others.....
    Tony Proasi
    52 split window coupe
    See if a caliper is dragging. The wheel might be "hot" if it is. Pull them and rebuild.
    Good luck,
    Tom
    Early S Registry #235
    rgruppe #111
  1. Mystery Noise
    By guycrosby in forum Technical Info
    Last Post: 04-24-2011, 10:53 AM
  2. door noise
    By scargo70 in forum Technical Info
    Last Post: 03-21-2011, 09:28 AM
  3. What is that noise?
    By raspy2point2 in forum Technical Info
    Last Post: 03-30-2010, 08:59 PM
  4. Engine Noise!!!!!!!
    Last Post: 07-23-2005, 03:44 PM
  5. transmission noise?
    By james in forum Technical Info
    Last Post: 01-05-2004, 11:57 AM
