Thread: 356 Guys, What are these parts?
    Nov 2002
    Worshington State
    A year ago a good family friend died and left his son his pristine 356B cab, and his widow a box of parts (which the son could see no use for since he is not the DIY type). I agreed to sell the parts for her on ebay, but am having difficulty determining exactly what these last few stragglers are.
    - One appears to be a bumper overrider (front?) but have seen no pics of 356Bs with this.
    - The next one is a chrome mounting piece with two bolt holes which I am guessing some type of exterior light was attached???
    - The other is a BEHR cooler. Is it for oil or transmission fluid?
    - The last is a hanger of some sort (exhaust?) which is made of a heavy duty rubberized strap with holes in it. Don't know if this has any value at all - if not, I will pitch it.
    Any help on identifying these items would be appreciated.
    Sep 2006
    Maryland
    Top part of bumper overrider
    Looks like part of front turn signal base
    oil cooler
    not sure if the hanger is a 356 part.
    These parts have limited value in my opinion.
    Rob Abbott
    Nov 2002
    Worshington State
    Thank you for the reply.
    I agree about the value parts and are probably more trouble than they are worth and since most are flawed - or well used, probably will not post. Thank you for your input.
    Regards,
    Rick
    I think the funny hanger part is the strap that holds the handbrake cable up out of the way.
    Cheers
    Nov 2002
    Worshington State
    Quote Originally Posted by LGK6D
    Cheers
    primitive! (but probably effective). Thanks David.
  1. What do you guys think of this one?
    By Max (SD) in forum General Info
    Last Post: 09-14-2013, 03:47 PM
  2. 928? What do you guys think?
    By tom dance in forum General Info
    Last Post: 11-08-2007, 06:28 PM
  3. Did you guys see the $24K 74 914 2.0?
    By WM711 in forum General Info
    Last Post: 08-17-2007, 11:01 AM
  4. Where do you guys order your parts from?
    By bowdie in forum General Info
    Last Post: 08-03-2007, 07:56 PM
  5. 72 and 73 guys help!!!
    By deoxford in forum Technical Info
    Last Post: 11-23-2004, 04:25 PM
