Results 1 to 9 of 9
Thread: Early Dashboard "Buttons"
    '65 and '66 Dashboards had four exposed mounting screws at the windshield side. The screw heads were covered with some sort of "button". I can't find out what it looked like or what it was made of. Any information would be greatly appreciated.
    Jerry Weiland
    64-65 Dash buttons
    Hi Jerry (welcome),
    The dash button are a mushroom head sheet metal screw with a plastic cap/cover.
    They are similar to Photo 1, from a early 1960's VW bus interior. The difference is diagram 2, Porsche had a profile of "A"and are black, VW is the "B" profile - VW come in black or brown depending on year/interior. The little skirt can be buffed off to emulate the porsche part.
    Photo 3, is the center 4 buttons with a fifth over the glove box (but 4 button sounds sexier than 5 button - so the name stuck).
    Around spring/summer 1965 the buttons went away.
    Bob
    Early S Reg #370
    Dash buttons
    Detail photos of the buttons on an early dash.
    Bob
    Early S Reg #370
    Aug 2006
    Chicago area
    Hi Jerry. Welcome to the Early S Registry. I am glad you took my advice and joined us here as there is a wealth of information from our members. You will probably find all the answers from the Registry members that you are looking for during your renovation. Good luck and welcome!
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    Mar 2006
    Louisville KY
    How are those seats coming Jerry?? Het those cars look familiar
    Tony Proasi
    52 split window coupe
    Aren't both yours and Kevins 1965's great looking cars. What a drive.
    Bob
    Early S Reg #370
    Does anyone know where these screws and buttons can be sourced? I need them.
    Erich
    Early 911S Registry #263
    Nov 2010
    Highlands,Nc
    Yes. Looking to source the screws and buttons. Thanks
    1965 911 Factory Paint to Sample Orange
    1967 911S Bahama Yellow
    1968 911 S Blood Orange
    1971 911S Gold Metallic Peter Gregg
    1974 Carrera RS Blue Metallic
    1990 RUF RCT Estonia's car
    These are just a little larger than the originals on 301022 but very close.
    if the link expires search black smooth licence plate frame screw cap and it should find something.
    https://www.ebay.com/itm/32-Black-Sm...72.m2749.l2649
    Membership #3255
    301022
    revivem.co.nz
  1. 15" tires for early rsr w/9"-11"x15" fuchs
    By rennmeister in forum Technical Info
    Last Post: 07-06-2016, 05:04 PM
  2. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    By Allen Henderson in forum For Sale: 911 Parts
    Last Post: 03-17-2012, 07:56 AM
  3. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 03-03-2012, 08:51 AM
  4. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 02-18-2012, 09:24 PM
  5. Replies: 0
    Last Post: 09-27-2007, 03:33 AM
