Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: SS heat exchangers, missing tube?
  1. #11
    pics
    here's a few shots of the set up on my 73S motor
    Richard aka le Zookeeper
    early reg #1128
  2. #12
    more pics
    mmore photos and its about 1" inch O.D. or 26mm
    early reg #1128
  3. #13
    In Zookeepers
    picture above, the hose outlet for the 72-73 "air regulator" intake is capped off. On the SSIs it is not present. So note that these OEM ones (too bad not stainless) have really an extra sheet metal jacket around the three piper as they come out of the back (front of the car) primary vertical sheet metal heater assembly. Here is a drawing from PET for the 72-73 only left MFI heat exchanger with the intake circled in red. What I did was just run the paper/foil hose down through its hole and leave it open. Some heat would eventually rise up through.
    -Allen-
  4. #14
    Senior Member Neunelfer's Avatar
    Dec 2002
    Sandy, Utah
    Looks like we found that sparkplug Zookeeper has been looking for!
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    80 VW “Caddy” Pickup
    72 R75/5 Toaster Tank
    PMB Performance
    Love Us On Facebook
  5. #15
    Quote Originally Posted by Tom F. View Post
    The tube that you point out is absolutely essential. It's needed for the warmup regulator on the pump. You have to order the SSI's with the [25mm] tube. Ironically, my CIS T, which doesn't need the tube, has it!
    Reviving an old thread but I have question that I think nobody asked before. Factory race cars didn't have any heat exchangers at all, as they had headers instead, so, what alternative source did they use for the warm-up regulator on the MFI pump?
  6. #16
    Aug 2011
    Eugene, OR
    I don't think they had warm-up regulators at all. Or at least not this type. Cold starting is a not a big concern for racing.
    - Arne
  7. #17
    Aug 2009
    SF Bay Area
    FYI the picture from Pelican parts is not a SSI heat Exchanger. It is some brand X
  8. #18
    Quote Originally Posted by Arne View Post
    So, how did they enrich the mixture for cold starting if there's no warm-up thermostat?
  9. #19
    Aug 2011
    Eugene, OR
    Quote Originally Posted by blue72s View Post
    Any number of possibilities. Small squirt of fuel by hand into the stacks, or a hand operated screw or lever in place of the thermostat. Racing is a totally different scenario, and unlike with a street car there's no expectation that the driver will simply get into a bone-cold car and expect it to start up unattended. So less mechanically complex is better.
    - Arne
  10. #20
    Move the rack inside the MFI pump by hand. There is a fitting for this on the back of the pumps for race cars, as I recall.
    Tom F.
    Long Beach, CA
  1. FS: Heat Exchangers
    By cjtbt in forum For Sale: 911 Parts
    Last Post: 12-12-2013, 11:43 AM
  2. SSI Heat Exchangers
    By Aircool in forum Technical Info
    Last Post: 05-10-2013, 01:33 PM
  3. WTB - Heat Exchangers - 69 E
    By Steve G in forum For Sale: 911 Parts
    Last Post: 12-07-2005, 07:28 AM
  4. SSI heat exchangers
    By Ed B in forum General Info
    Last Post: 09-05-2005, 06:33 AM
  5. SSI heat exchangers & MFI
    By 911kiwi in forum Technical Info
    Last Post: 07-14-2004, 05:52 PM
