Thread: Bosch 3 Pin CDI Fix Needed
    Apr 2007
    Slovakia
    My 3 pin CDI Bosch does not whine; I found that diode D5 is broken (physically) and smells. What is the best way to get replacement? Get the replacement from other faulty Bosch ignition, or can I get in shop or is there a way how to find out its parameters, so that I can search for equivalent? I checked all the ignition threads on Pelican, but did not find this info, not even in Early S Man's posts.
    Does anyone having broken CDI with good D5 willing to sale/part with? That is the only component I need for fixing mine.
    Martin
    Bosch 3 pin CD fix needed
    I can't help with finding that one part, but Systems Consulting
    (system sc @systemsc.com) can repair them.
    Jan 2003
    UK
    Martin - you should be able to find the part you need at any good electronics parts supplier - do a search on google for Zener diode.
    In the UK we have suppliers like RS Components, Maplins, etc.
    Andy
    Early 911S Reg #753
    R Gruppe #105
  1. FS: NOS Bosch early wiper blades with the bosch symbol
    Last Post: 10-21-2014, 12:41 AM
  2. Replies: 1
    Last Post: 08-25-2013, 07:58 AM
  3. Replies: 2
    Last Post: 10-04-2012, 09:31 PM
  4. Bosch Distributor info needed
    By ESully in forum Technical Info
    Last Post: 05-04-2012, 03:54 PM
  5. Bosch distributor info Needed
    By Peter Aziz in forum Technical Info
    Last Post: 10-07-2008, 11:32 AM
